09-08-2013, 05:35 PM | #1 |
Rep 26
Drives: 2009 BMW 128i
dont know how to explain it - weird noise...
i have this weird spaceship sounding noise when i drive...
its like a whomwhomwhom type sound. i recently had all 6 sparkplugs changed out.... dont know what it could be...any ideas? |
09-08-2013, 05:54 PM | #2 |
Rep 528
what kind of spark plugs did you use? (are they from the dealer) how many miles on the motor/ you think you could post a video?...I've read recently across the forums many issues coming from not using the "dealer" based spark plugs
09-08-2013, 06:00 PM | #3 |
Rep 22,992
Make a video and post it. Try to make the noise happen a few times. Then we can see what it is. ? Other wise we will all just be taking a wold guess.
09-10-2013, 04:05 PM | #4 |
Rep 26
you can clearly here the noise in this video. idk how to explain it. i think it may be coming from the engine...but not entirely sure...this video was windows up, air off, and i tried to hold the same speed - its not air just passing the car, i have no idea what it could be...as for the spark plugs i took it to specialty shop and asked if i could get bmw brand plugs same w the coil replaced.
09-10-2013, 04:34 PM | #5 |
Rep 2,239
changes with speed and not RPM, so i doubt it anything motor related. wheel bearing, tires, something of that sort is my guess.
08 e93 335i MT
09-10-2013, 06:48 PM | #8 |
Rep 26
i just feel regular engine vibrations. ill get wheel bearings checked out
and im to dip that soon |
09-10-2013, 07:16 PM | #9 |
Retired and loving it!
13
Rep 154
Has anyone else driven the car?
Did they test drive it after replacing the plugs? It does sound like drivetrain. I assume you have closely checked rims and tires.
2012 135i (MO OIFIG) 2013 Subaru Legacy 1971 Z28 |
09-10-2013, 07:41 PM | #11 |
Rep 26
yeah the mechanic who did the work drove it said it was fine, but that noise has been there since before i got the plugs changed out though.
09-10-2013, 08:01 PM | #12 |
Rep 272
Drives: 2008 128i
If it changes pitch when you turn left and right it is the wheel bearing. That's what it sounds like to me. A good shop should have a chassis ear to hook up to it and locate which side it is. They should be replaced in pairs, but don't really have to if money is an issue.
Afe Scoops and CAI, PBX, BMS Paddleshift upgrade, 261M's Powder Coated Gunmetal, 225/255 Michelin PSS, (BMW Performance: BBK, Illuminated Door Sills, Shifter Knob and Boot, E-Brake Handle, Steering Wheel, Front Strut Bar), E93 FSB, E92 RSB, M3 Rear Subframe Bushings, M3 Front Control Arms, HPA coilover kit (Koni Adjustables and Swift Springs), Steel Brake Hoses, Black Kidneys, Smoked LED side markers, Blacklines, Msport lip spoiler...
09-10-2013, 08:53 PM | #13 |
Rep 528
idk Id say check your tires also? (strange is it may sound but are the wear bars showing) from looking at the video again *granted I could be wrong* but Im not sure if its the wheel bearing since that makes a bit more of a wailing noise
09-10-2013, 08:56 PM | #14 | |
13
Rep 154
My point was did the mechanic kiss a curb....hit a pothole.....?? But if the noise was there before the plug change then I'm way off base. I can always tell a wheel bearing is gone when I have the car up on a hoist and I spin the wheel but if it's hard to tell then a mechanics stethoscope will help. Good luck.
09-10-2013, 10:57 PM | #15 |
Resident Tamed Racing Driver
298
Rep 4,697
Easy way to confirm if it is drivetrain/tire/wheel bearing related would be to put it in neutral at speed.
09-11-2013, 01:11 AM | #16 |
Rep 26
if it is the bearings, any recommendation on brand or is standard bmw fine?
09-11-2013, 01:17 AM | #17 |
Rep 528
or *a dumbified way to check the bearings* when the car is parked see if the wheel has any play -> with your hand at the top shake it in the direction towards the strut and out back to you (inwards and outwards) and yeah overall PLEASE stick with the BMW bearings (assuming thats the issue) the last thing you would want would be the cheap ones heat up to the point they become 1 with the knuckle....and TRUST ME that is not pretty
09-11-2013, 02:34 AM | #18 | |
Rep 26
i generally try to go with original parts or upgrade/performance parts |
09-11-2013, 10:28 AM | #19 |
298
Rep 4,697
Get the originals.
09-21-2013, 10:43 PM | #20 |
Rep 393
Tires first, bearings second.. I've been down that road before and replaced a good sealed bearing with another good sealed bearing when it was the tire all along.
09-22-2013, 07:34 AM | #21 |
Rep 272
Drives: 2008 128i
Did you figure this out yet? Another way to tell if its the tires is if the noise gets louder during heavy braking. Also if the tires are lumpy, causing the noise, you may need struts.
