      09-26-2022, 10:00 AM   #1
mwikina977
mwikina977's Avatar
Drives: 2010 135I M-Sport
2010 BMW  [0.00]
2010 135i M sport ( 6 speed) space gray
BIMMERPOST / Classifieds
Asking Price:
USD 16.00
Item Interest
2010 135i - Msport pkg
150k miles
6-speed manual
Space Gray
Black leather interior/ silver trim
WBAUC7C53AVK81057
2nd owner
The car needs absolutely nothing, runs, drives perfectly, she is driven less than 2k miles per year, and has seen the very light autocross.
Fun to drive, Suspension is beefed up to handle the extra power, and it's very responsive.
I've done my best to bulletproof and baby the engine since ownership
No accidents, feel to run a carfax
Always stored in the winter, so zero exposure to salt and winter driving conditions since my ownership
Most of the work on the car was done at reputable shops, Auto engineering/ EuroTech Motorsports
Corner balanced and aligned by Auto engineering
Original turbos, zero boost leaks, pull excellent
The car is currently on Enkei TS-V s will be sold with the OEM Wheels m sport wheels on the side (see pictures)
Current wheel specs: Enkei TSV Tuning series wheels wrapped in Kumho Ecsta PS91s. TPMS is included. Staggered wheels. Fronts 18x8.5 38mm offset. Rears 18x9.5 40mm offset. 5x120 lug pattern.
List of Mods done below:
----Engine---
BMS - Charge pipe
(TUNED) MHD OTS Stage 2+
Afe Magnum stage 2 DCI
ARM 5" FMIC
1.75" VRSF inlets
Front Air scoops
RB Turbo PCV upgrade
BMW Cowl filters
Mishimoto oil catch can
---Suspension---
E90 M3 Control arm upgrade Front+ Rear (installed @147k miles)
BMS Diff Brace
Dinan fixed camber plates
Eibach front sway bar
Eibach rear sway bar (not installed but will come with the vehicle)
Truehart adjustable toe arms
Bilstein B14 coil overs (installed @146k miles)
---Exhaust-----
Cobb high flow catted downpipes
N55 mid-pipes
Berk race axel back
-----Misc----
Mini RTD Shifter
Updated Halo bulbs
Blackline taillights
CDV delete
Maintenance since ownership
~~~~143k
Eldor Coil packs
1 Step colder NGK (gapped. 022)
~~~~145k
Oil Change - Euro Tech
Upper Radiator hose
Upper expansion tank hose
New battery
~~~~146k
Oil change - Herb BMW
~~~~147k
Front + Rear Brakes
(Stop tech slotted rotors + Stop tech sport pads)
Price 16k
-$1000 without the Enkei TS-V wheels (Willing to sell wheels separately for 2k)
* Videos on demand
* Selling due to real estate purchase
Boston
10 135i / M Sport - Space Gray
BMS - DCI | BMS - CP | VRSF 1.75" INLETS |
ARM 5" FMIC | COBB HF DP's |BERK RACE AXELBACK
MHD STAGE 2+
135 135i manual n54, 135i
