      07-14-2009, 02:01 PM   #1
STETT Performance
Drives: FAST
STETT Performance 135i/335i BOV or Dual DV Charge Pipe GB -- Will NOT Blow Off !!
Ladies and Gentlemen,
**NEW** Includes Meth Bungs!
It's official, our next generation BOV and dual DV charge pipes are here! We have taken the already popular first gen charge pipe and added dual stainless meth bungs. They come pre-tapped 1/8-27 NPT with stainless plugs. Whenever you are ready to add Meth you simply remove one or both of the plugs, install your nozzle(s) and VOILA!
For those of you not yet familiar with our charge pipes, you maybe familiar with the horror stories of people blowing their stock or aftermarket charge pipes off while under boost, hello limp mode, hello check engine light and goodbye to the guy next to you who just ate your lunch because because your BMW just blew it's charge pipe off. Here's a little information everyone should read.
*PROBLEM: The factory charge pipe has a 3mm flimsy oring that seals it off to the throttle body... YES, a little o-ring. The pipe relies on a weak metal push lock clip that slides down into a groove on the throttle body and locks the pipe into place. This, like the weak factory diverter valves, will only seal for so long until you start getting oil leaking out around the connection and eventually POP, boost pressure overcomes the lock clip and your charge pipe flies off ripping the TMAP sensor apart. Guess what? If oil (heavier than air) is finding it's way past the oring then where do you think boost is going? Go out to your car and look down where your charge pipe connects to the throttle body.. do you see the oil residue? If not, you will. If your pipe hasn't come off, it will. Some aftermarket pipe manufacturers use this same style flimsy oring and weak clip design, so how is this improvement over stock? Well then, let's just grab a silicone hose and stick a pipe on there and we solve that problem. WRONG. The problem with this is that there is nothing for the hose and clamp to grab onto. Eventually... POP, the pipe comes off.
Back in early 2007 we identified this major design flaw and immediately came up with a solution that eliminates the charge pipe blowing off issue and also provides over 4 times sealing capacity than that of the oring style setup. OUR CHARGE PIPES WILL NOT BLOW OFF. We offer the charge pipe with either 50mm Tial BOV or dual Forge Diverter valves. We do NOT use the Forge OEM replacement valves because the factory push lock connections are not ideal for use with a hose. We use a better suited version of the Forge DV.
- All charge pipes are made from 304 stainless steel (aluminum is soft and will crush under heavy pressure from t-bolt clamps)
- All pipes utilize our patented throttle body connector, ours WON'T blow off
- Our throttle body connector provides over 4X the sealing capacity over the stock/aftermarket oring style design
- *NEW* Dual stainless steel Meth ports (come with stainless plugs)
- Available options:
--BOV charge pipe with Tial BOV
--BOV charge pipe with Tial BOV flange (NO BOV)
--Dual DV charge pipe with dual Forge diverter valves
--Dual DV charge pipe (NO DIVERTER VALVES)
- Black powder coat finish for a sleek look and added durability
- Stainless TMAP sensor bolts
- Heavy duty 4 layer silicone hoses
- Heavy duty T-bolt clamps
- Pressure tested to 30+psi --WILL NOT BLOW OFF
We manufacture our products using only the best quality materials. Each pipe assembly is hand made in house. We only use high quality BOV's and DV's from the two best names in the industry, Tial and Forge Motorsports.
BEST CAI ON THE MARKET: Former_Boosted_IS review of the STETT Performance Cold Air Intake vs. Dual Cone Intake - http://www.e90post.com/forums/showthread.php?t=262528
ATTENTION 135i OWNERS: Our 135i CAI is the only one on the market that puts the filter behind the bumper, not under the hood: it DOES make a difference!
Want to hear the STETT Performance Tial/BOV? You Tube Sound Clip http://www.youtube.com/watch?v=exoo3...layer_embedded
NOW, to the part everyone has been waiting for..... GROUP BUY!
We are going to include shipping anywhere in the Continental U.S. If you're outside of the U.S. please PM us for additional shipping.
A. BOV charge pipe group buy -- $440 shipped $565 retail
B. DV charge pipe group buy -- $470 shipped $595 retail
C. BOV charge pipe group buy (Tial 50mm flange only) -- $245 shipped $295 retail
D. DV charge pipe group buy (No DV's) -- $245 shipped $295 retail
We need a minimum of 14 orders.. let's start with those already chimed in from another feeler in the forums..
1) B. Cincy335i - DV kit
2) A. Ville - BOV kit
3) A. LemansE82 - BOV kit
4) B. ThorsHammer - DV Kit
5) B. 2008_335i_coupe - DV kit
6) A. JPSlick - BOV Kit
7) A. XPO186 - BOV Kit
8)
9)
10)
11)
12)
13)
14)
This is a picture of the factory charge pipe showing the little oring that seals it to the throttle body and the weak lock clip that holds it all on...
      07-14-2009, 02:34 PM   #2
LemansE82
Formally known as xXxMLEExXx.
LemansE82's Avatar
Drives: Lemans E82
Stett...My name is already on the list. My question is did you guys have the production version in stock? I have an event coming this weekend and would like to have available for use.
My 1 borned on 03/26/09
On the ship...eta NJ 04/16.
Picked up 04/24/09
      07-14-2009, 03:17 PM   #3
scawacs
Drives: 1
8) B. scawacs - DV kit
9)
10)
11)
12)
13)
14)
      07-14-2009, 03:26 PM   #4
STETT Performance
Drives: FAST
9) B. NMS335 - DV kit
10) D. CB7 - DV Pipe (No DV's)
11)
12)
13)
14)
      07-14-2009, 11:58 PM   #5
SoQuick
Stock
Drives: Nothing now
2009 135i  [0.00]
2001 S8  [0.00]
11) C. SoQuick - BOV Pipe (No BOV)
12)
13)
14)
      07-15-2009, 01:11 AM   #6
jwdyeung
Drives:
12) D. jwdyeung - DV Pipe (No DV's)
13)
14)
      07-15-2009, 01:12 PM   #7
zracing135i
Forged!!!!
13) A. zracing135i - BOV kit
14)
Last edited by zracing135i; 07-15-2009 at 01:13 PM.. Reason: name was not posted on the list.
      07-15-2009, 09:54 PM   #8
supracg
So the BOV charge pipe (no BOV) wouldn't work with the synapse BOV right?
      07-16-2009, 08:59 AM   #9
STETT Performance
Drives: FAST
Not unless they provided an adapter flange
      07-16-2009, 09:23 AM   #10
STETT Performance
Drives: FAST
Ok guys/gals, we hit the 14 mark. We need everyone to PM us with a good contact number so we can call for payment. As soon as we get everyone confirmed then we'll start shipping these out!!
4) B. 2008_335i_coupe - DV kit
5) A. JPSlick - BOV Kit
6) A. XPO186 - BOV Kit
7) B. scawacs - DV kit
8) B. NMS335 - DV kit
11) D. CB7 - DV Pipe (No DV's)
12) B. SD135i - DV Kit
13) D. MelaD - DV Pipe (No DV's)
14) C. SoQuick - BOV Pipe (No BOV)
15) B. harper121 - DV Kit
16) D. jwdyeung - DV Pipe (No DV's)
17) A. zracing135i - BOV kit
18) B. vampie - DV Kit
19) B. hardNock - DV Kit
20) B. Crazy AWD - DV Kit
21)
22)
23)
      07-17-2009, 10:50 AM   #11
kc_skyrider
kc_skyrider's Avatar
Drives: 2009 135i M-Sport
you can mark me down for a BOV pipe (no bov) and mark as paid. Called up and talked to you guys today. PS great customer service!
      07-17-2009, 10:59 AM   #12
LemansE82
LemansE82's Avatar
Drives: Lemans E82
Chad,
Is a great person to deal with, really helped me out in getting the kit
to me for my even this weekend. Package arrived, today as promised.
Can't wait to pick it up later.
Picked up 04/24/09
      07-20-2009, 09:23 AM   #13
LemansE82
LemansE82's Avatar
Drives: Lemans E82
Just want to let everyone who has a Injen intakes that the BOV kit will clear with space to spare. I will try to get some pics shortly.
Picked up 04/24/09
      07-20-2009, 11:04 AM   #14
NihonX
Drives: 2011 VO 1M
I need one of these...
I won't be able to order until next payday though.
      07-21-2009, 12:12 AM   #15
SoQuick
Stock
Drives: Nothing now
2009 135i  [0.00]
2001 S8  [0.00]
STETT Won't provide an adapter, but you can get it online from a few Synapse Engineering dealers. I've seen the Synapse BOV for as little as $203 and the Tial adapter is around $28. This is what I'm going to do. I want to be able to vent or recirculate. I have high hopes for the STETT charge pipe and the Synapse BOV.
      07-21-2009, 12:15 AM   #16
SoQuick
Stock
Drives: Nothing now
2009 135i  [0.00]
2001 S8  [0.00]
Here is the BOV
http://www.dezod.com/pd-synapse-engi...-universal.cfm
Here is the adapter
http://www.dezod.com/pd-synapse-engi...-stainless.cfm
Only problem for me is I can't find a Synapse dealer that sells the adapter aswell, to ship to my APO.
      07-21-2009, 09:57 AM   #17
rocketpop
rocketpop's Avatar
Oh man this is so tempting! Chad, can you PM and "installed" price on a charge pipe with a tial.
Dennis
      07-21-2009, 10:33 AM   #18
akak1997
akak1997's Avatar
63
Drives: BMW 135 @ 135mph
2008 135i  [0.00]
Tempting..... got a pic with the DVs?
I also like the CAI, but I'm concern about hydro lock. Is it possible to put a valve in place of that flex hose? What diameter is that pipe? Maybe include the valve in your kit?
      07-21-2009, 02:45 PM   #19
ki__
Drives: 19 M2C 6MT
Im a noob to these things, what is the difference between the two?
      07-21-2009, 03:17 PM   #20
BSM 135i
BSM 135i's Avatar
Drives: 08' BSM E82
BOV's release the air into the atmosphere hence the wooosh sound and DV's recirculate the air into the intake like the stock DV's but they will handle more boost.
      07-23-2009, 12:09 AM   #21
ki__
Drives: 19 M2C 6MT
so u can actually hear the BOV unlike the DV?
      07-23-2009, 10:12 AM   #22
STETT Performance
Drives: FAST
A valve is not needed. Getting a little moisture into your engine is normal and doesn't hurt (think of water/meth mix). If you submerge your car in standing water high enough to put the CAI filter under water, soak the filter and then fill your engine with water.. then you have far greater problems than a wet air filter We have had our 335i CAI's on the market since early 2007 and never heard one issue of water problems.
