11-24-2009, 02:52 PM | #1 |
Joint Chiefs of Staff
4918
Rep 115,980
JB3 *Meth* Kit - Several Kit Options Now Shipping
Methanol/Alcohol/Water injection, commonly referred to as "meth", allows you to make tremendous amounts of power on pump gas. The effect is similar to running 104 octane all the time, with additional cooling benefits allowing for more power than you could ever make on race gas alone. The install is challenging, requiring you to drill and tap a location for the nozzle, but the performance benefits greatly outweigh that.
This unique kit locates the methanol pump in the 1.5 gallon tank for easy install and removal. The tank/pump then can be placed anywhere in the trunk for easy access and removal. We've selected the 250psi pump for its superior atomization and flow characteristics relative to less expensive 150psi pumps. This kit also features a check valve for reliability and a 7GPH (M7) injection nozzle perfectly sized for the 380-440whp range. The basic kit includes a boost activated on/off switch. For those who want a more sophisticated system we also offer the CMGS methanol controller gauge, which features adjustable progressive spray, boost readings, and other adjustable options. It also includes the CMGS flow sensor which allows the CMGS to display methanol flow and trigger the JB3 to go to a higher boost map ONLY when the methanol is properly flowing. Due to the heavy weight of the basic kit shipping is fixed at $22 for domestic UPS ground. The kit will ship ground regardless of what shipping option you select at check out. Please inquire about international shipping rates. The pictures below are of the quick-mount kit. N54 Basic 250psi trunk mount N54 methanol kit - $355.00 http://www.n54tuning.com/index.php?_...d&productId=37 N54 Meth kit w/ CMGS, No Tank - $615.00 http://www.n54tuning.com/index.php?_...d&productId=46 N54 Meth kit w/ CMGS, 1 gal "universal" Tank - $660.00 http://www.n54tuning.com/index.php?_...d&productId=45 N54 Meth kit w/ CMGS, 1.5gal "quick mount" tank - $699 http://www.n54tuning.com/index.php?_...d&productId=39 |
12-01-2009, 01:07 PM | #4 |
4918
Rep 115,980
12-01-2009, 02:36 PM | #5 |
Rep 5,689
I mean is it the same thing that cmgs has with the lines and such cut to be the exact legnth for the 135i or is it the general one?
If its the general you might want to chech your price. |
