11-25-2009, 08:16 PM | #1 |
Rep 4,038
-=EMS=-Riss racing *Black Friday BLOW OUT*
Well its that time of the year again and thanks to Riss Racing we have some spectacular Deals to pass on 1addicts members.
Riss Racing 135 Exhuast [u2b]h6w3BWgsLnY&hl[/u2b] WAS $1199.00 NOW $699!! Get the full potential of power and sound from your 135i with Riss Racing’s 3” fully mandrel bent 304 stainless steel exhaust. Get power gains of 20+hp with a nice throaty authentic BMW sound that you would only expect from an M series but with the difference of hearing your twin turbos spool to redline. This is the world record holding Riss Racing 135i exhaust. Holding records in both Dyno numbers of 422 whp & 1/4 mile ET record of 12.5 @ 117 mph. As seen in out "dyno results section" The exhaust is constructed of mandrel bent 304 stainless steel. Starting with a Y pipe from the downpipes too a full 3 inch all the way back. No corners cut even the internals of the muffler are constructed of the highest grade 304 stainless with the signature RR plating this is the #1 exhaust to run on your 135i! Riss Racing 3'' Catless Downpipes Riss Racing 3" Catless Downpipes (Polished) WAS $699.00 NOW $499 Riss Racing 3" Catless Downpipes (Ceramic coated) WAS $799.00 NOW $599 The Premier downpipes for the BMW 135i/335is N54 motor are available now! As any turbo car owner knows, offroad downpipes usually yield the largest gains in power for a bolt on product. Other than a Tune/flash, downpipes can NET you 2X or even 3X more power than an intake or catback exhaust system. Riss Racings 3" Offroad Catless downpipes improve your twin turbos flow by reducing back pressure and increasing power to an UNCANNY 330HP and 350TQ rocket! Constructed of 100% 304 Stainless Steel, this is the top quality grade Offroad downpipes available on the market. Installation is able to be done with a novice mechanic. Our techs can also help with the process during installation! Available in Polished and Black Stealth Ceramic Coating! * Now included with every purchase, Riss Racing 2.5" downpipe gaskets Riss Racing N54 O2 Simulator WAS $79 NOW $59 No more CEL/limp modes for your catless N54! Now you can run high flow cats/cat-less downpipes for your 135i/335i without a code (P0420 and P0430) relating to your catalytic converters. Keep your vehicle running on the track with no problems at all. Riss Racing Oil Catch Can (Anodized Black) WAS $85 NOW $64 Keep your motor running clean and perfect with the Riss Racing Catch Can! This is an absolute must for ANY N54! Riss Racing's Oil Catch Can takes all the excess oil and moisture in the blow by and diverts it into the canister. Now, you will not have to worry about carbon sludge buildup in your intake, intercooler and turbo hindering the performance of your daily driver or weekend warrior. Comes with the authentic Riss Racing logo and site tube which allows you to see exactly how much oil is being caught inside. -Anybody can do the test for themselves to see if they really NEED this. Step 1. Take off the intake, and run your fingers on the inside wall of the tubes leading to the turbos. What do you see? You can do the same for your intercooler down to the actual turbo housing and charge pipe. Cleaner engine means more performance. To Order http://www.exquisitemotorsports.com All Sale items are instock and ready to ship! *SALE ENDS TUESDAY* Do not miss out on these great deals ! Last edited by Andrew@ET; 11-25-2009 at 09:04 PM.. |
