01-18-2011, 06:26 PM | #1 |
Rep 3,160
**********s | BMS CAN Tool (CT) N54 / N55
[IMG]http://www.**********s.com/images/Products/Front_banner/Colored%20Banner.jpg[/IMG] BMS CAN Tool (CT) N54/N55 Engine (135i, 335i, 535i, Z4 35i, etc.) Give your N54 or N55 a useful new tool, the BMS CAN Tool (CT)! [IMG]http://www.**********s.com/images/Products/BMS/BMW_can_reader_toolS.jpg[/IMG] Tired of having ECU codes pop up on your dash and not being able to remove them, or tell why they are popping up? Look no further than the BMS CAN Tool, The Burger Motorsports CAN Tool (CT) can; read and delete ECU error codes, display boost and timing on your existing gauges, user adjustable dash shift lights, and has many more features to come. The CT Tool simply plugs into your BMW's OBDII to provide for quick install and removal. The BMS CAN Tool (CT) is the perfect addition to anyone running any type of aftermarket tune on their N54/N55. Please note that to display actual boost pressure with a piggyback tune you will need an ECU mounting harness. In OBDII mode the boost pressure will only be accurate on stock and ECU re-flashed cars. Features
Applications The BMS CAN Tool (CT) works on all BMWs with the N54, N55, or turbo diesel motor
BMS CAN Tool -- ECU mount steering wheel control demo BMS CAN Tool testing, timing on fuel and IAT on oil temp [IMG]http://www.**********s.com/zoom_img/_1284556720.jpg[/IMG] Any questions, PM, E-mail, or give us a call at ************** |
