03-09-2010, 08:17 PM | #1 |
Rep 6,916
Teaser pic of Sonax Wheel Cleaner - the ultimate wheel cleaner??
SONAX Wheel Cleaner
Precision Wheel Cleaner for safe and effective removal of brake dust and stubborn dirt SONAX Wheel Cleaner is a highly effective, acid-free and pH balanced rim and wheel cleaner that is safe for all wheels, including aluminum and alloys. This formulation is also effective and safe for use on painted wheels and will not deteriorate clear coats. SONAX Wheel Cleaner contains unique chemical ingredients that effectively dissolves the sintered iron by forming a water soluble iron complex. During the use of your vehicle, brake dust and road grime become sintered to the surface of rims and wheels due to the high temperature conditions they are normally exposed. Brake dust contains high levels of iron and once sintered to the rim, becomes extremely difficult to dissolve or remove without the use of harsh chemicals. SONAX Wheel Cleaner sprays on as a thick, flourescent grean foam. As the cleansing foam begins to work into the dirt and grime, the formula begins to turn red. The red coloration is the SONAX Wheel Cleaner forming a bond to the sintered iron on the wheel and changing its state to a water soluble complex for easy removal. Stubborn, baked on grime may take a small amount of agitation. Rinse wheels thoroughly with a power washer and wipe dry. MSRP - $19.99. So here is the test I did over the weekend. First I used this on the VW R32 and got amazing results, unfortunately no pictures. Was able to do some more testing and the test subject a 2010 Audi S4, with all the bad weather I figured this was a great time to test it out. 4-5 weeks without washing the car (due to rain, snow, northeast winter) Take a look I followed the instructions to the tee and got some amazing results, dare I say this will be a hit! I'm going to say even better than my favorite wheel cleaner. Before shot of the wheel Sprayed it on, and it was immediately green as stated in the directions Started to turn purple within minutes Take a look at it cleaning. (this was after quickly using the Uber Spoke Brush and Uber Boar's Hair Brush nothing crazy just a quick brushing) Used a power washer (Cam Spray) and they looks great! Needless to say I was impressed so impressed we will be carrying this asap. I know most know what my favorite wheel cleaner is here and I've been using it for 15 years and I think I just found its replacement. |
03-09-2010, 11:42 PM | #6 |
Rep 6,916
Updated: with the HUGE Response on this item I will start the pre ordering now. Shipment should be here in 5-7 days.
Click here to reserve yours today SONAX Wheel Cleaner. (Don't forget to add your discount code) |
03-10-2010, 09:16 AM | #8 |
Rep 6,916
03-10-2010, 11:46 AM | #9 |
Rep 9,160
Beauty, thanks! I see a kid seat in back, and that's why I'm considering an S4 to finally replace the M Coupe. There's a black one on my block and I keeps catching my eye and the active diff seems like a great improvement over older quattro setups.
03-10-2010, 11:51 AM | #10 |
Rep 6,916
unfortunately I maybe getting rid of the 08 R32 for a Q7 because I have a 7 year old and a new one on the way. The S4 is tight for a new born and all the stuff you have to lug around. Love the S4 though
03-10-2010, 12:56 PM | #11 |
Rep 9,160
Yeah, but it's not as tight or big of a pain as the 135i. I'd of course love an S4 Avant, but Audi USA doesn't seem to care. I'd consider a Golf R if we ever get it Stateside, and in five door, three pedal format, but I'm not holding my breath for that.
03-19-2010, 04:48 PM | #13 |
Rep 759
Drives: 128i Coupe 6MT
I'd love to know how this works with a regular hose. No pressure washer here so I wonder if the results are going to be the same as other wheel cleaners with regular pressure. Will have to wait for people to comment before buying. Looks awesome though I hope it pans out!
03-19-2010, 04:54 PM | #14 |
Rep 6,916
I believe this was done with a regular hose and some brushes.
100k miles on these wheels. http://www.xoutpost.com/bmw-related-...-pads-56k.html |
03-20-2010, 09:18 AM | #16 |
Unloved BMW Addict
86
Rep 1,185
Drives: Z3 Coupe, 3 318Ti
Ordered.
03-20-2010, 10:35 AM | #18 |
Rep 3,465
Drives: 997.2 GT3, '17 G30
So agitating is still necessary. I dream of the day we have a cleaner like this that is spray on, let soak, spray off!
ig: 0verrev
03-20-2010, 10:49 AM | #19 |
Rep 6,916
in some cases yes brushing is still necessary. there are wheel cleaners that can remove everything including your clear coat, they are acid based wheel cleaners
03-20-2010, 07:49 PM | #20 |
Rep 1,101
I have seen some cleaner that you can spray on and it will clean the wheel vertually clean. If they are super dirty you may need two applications. I also saw the damage done to the wheels after 3 years. Ouch! The finish was dull and pitted. The owner said it even did some damage to his driveway!
03-20-2010, 09:19 PM | #22 |
Rep 1,347
what is the reliability of this item on after-market wheels? I know there are many products which are too powerful, or too acidic?
JRZ RS2 | Capristo | Eisenmann | Volk Racing TE37SL | Endless Brakes |
