      08-10-2018, 01:38 AM   #1
xshadowspy
Drives: Black bmw 128i
N52 engine malfunction?
So I was just sitting in my car in park when out of nowhere my engine revs up and a engine malfunction pops up my car has 53k miles so I was wondering if maybe the car was being dumb so I turned it off and turned it back off and everything was normal no light and I drove it kinda hard to test if the light would come on but nothing could it be just a false alarm? Any thoughts anyone had similar experiences?
      08-10-2018, 11:06 AM   #2
Thunderguts
Thunderguts's Avatar
785
Drives: 2009 128i Sport MT
How high did it rev? Are we talking vacuum leak or WOT bouncing off the rev limiter?
A code should be stored. Gotta check it.
      08-10-2018, 07:34 PM   #3
xshadowspy
It reved up to around 2-3k maybe 4 not sure happened quickly and I have been having these random idle drops before in the city but I always thought it was how hot It was outside since here in california it's like 105 degrees
      08-10-2018, 09:07 PM   #4
Thunderguts
785
That’s more than any physical issue like a vacuum leak. It has to be computer related. You need a code reader ASAP before it happens again.
      08-10-2018, 11:58 PM   #5
smeard
smeard's Avatar
136
Drives: BMW
2010 BMW 128i  [0.00]
On older e36s, the TPS (throttle position switch/sensor) would go out and the things would rev away. The plastic gears in the switch would deteriorate or the sensor would just fail over time. Also, is the car modified? Maybe this could be it? I agree with Thunderguts that you should definitely read the code if it threw one. It is, after all, the car's way of screaming for help. Good luck my friend!
Commuter- F10 528i N20 8AT Jatoba Black
Show- F10 550i M sport 8AT Alpine White: Airrex Bags, 20" Forgestar F14s, Meisterschaft Catback
Around town- E60 528i N52, 6AT, Monaco Blue
Weekend - 1997 BMW Z3 M52, 5spd, Dunkelgrun: 230k mi, Intrax Springs on Bilsteins, Style 68s staggered
AutoX/track - 2012 F30 N20, 6MT BSM
      09-05-2018, 05:44 AM   #6
printerror
Drives: 2011 BMW 128i 6MT
Mine did that and threw a code for a bad coil. I replaced all six and the plugs (~$150) and the problem was solved in about an hour. Easy fix.
