      09-17-2018, 08:43 PM   #1
E30ROB
Drives: 2013 X5 35i M Sport AW3
128i 1M clone N52 FBO with full E85 + POV blue ridge VIDEOS!
Hey all, some of you have been following my build with the 128i
BPC and I took the 128i to another level with S65 fuel injectors and full E85.
In the video I still have secondary cats, which didnt last more than a day. Maddad midpipe on order!
Here is a video of the car on the Dyno for E85
We managed to squeeze out 252whp in 100* index climate, when I revisit the dyno in the fall I will have a euro airbox and catless midpipes.
https://www.youtube.com/watch?v=Ncs2Sm3y0Hw
ADDITIONAL POV video driving on the blue ridge parkway prior to tuning for E85. This was on 93 pump gas, making 248whp
https://www.youtube.com/watch?v=09cFeVym_0I
MCShred99.00
jemfff12.00
Fritzer944.50
      09-17-2018, 09:38 PM   #2
MCShred
Getting Risky ;)
MCShred's Avatar
Drives: 2010 128i 6MT Space Grey
So sweet, Need to make the trip down to BPC soon!
      09-17-2018, 11:19 PM   #3
Taskmaster
Japan
2465
Drives: M235i 6MT / E92 328 Msport 6MT
Post the chart.
And don’t bother with a retune until you have MILVs.
      09-18-2018, 09:43 PM   #4
E30ROB
Originally Posted by Taskmaster View Post
Post the chart.
Ill have to ask for the chart, I didnt have them send it to me just because it wasnt a drastic change and conditions were meh.
The plan is to do MILV's in the future but I have a few other things I need to focus on first (oil pan gasket, clutch upgrade, exhaust, rear end bushings).
I want to hit 300whp NA with it before it pops!
      09-22-2018, 11:39 AM   #5
chris_flies
Sideways and Smiling
chris_flies's Avatar
3027
Drives: In Exuberance
I'm curious about the S65 injectors. Are the stock ones not able to provide enough fuel, or is there another reason?
ornicar136.00
      09-24-2018, 09:43 AM   #6
Taskmaster
Japan
2465
Yes.
      09-24-2018, 02:59 PM   #7
chris_flies
3027
Yes.
There's another reason?
      09-24-2018, 03:47 PM   #8
Taskmaster
Japan
2465
No, they just don't flow enough - that's really it.
      09-24-2018, 04:02 PM   #9
chris_flies
3027
Hmm, interesting
      09-24-2018, 06:03 PM   #10
Patriot_Pat
Patriot_Pat's Avatar
Drives: 128
Wow impressive car.
At what point are the stock injectors the limiting factor?
      09-24-2018, 08:58 PM   #11
Taskmaster
Japan
2465
Originally Posted by Patriot_Pat View Post
Wow impressive car.
On pump gas, it looks like around 280whp, 230ish on E85 apparently
chris82827.00
      09-26-2018, 06:50 AM   #12
chris_flies
3027
Wow impressive car.
Are they a simple bolt-in affair? Would they need to be tuned/coded?
This is a whole new approach I haven't heard of before....
      09-26-2018, 09:23 AM   #13
Taskmaster
Japan
2465
You would want the car tuned for the new injectors yes, but why would you? Unless you're supercharged (and the ESS blower comes with them) or you're looking for a custom tune, don't bother.
      09-26-2018, 10:13 AM   #14
chris_flies
3027
That's what I figured.
The more you know...
      09-30-2018, 09:10 PM   #15
E30ROB
The injectors were very easy, rebuild kit and bolt them right in. I didnt need a retune on pump gas with them, the computer adapted perfectly funny enough.
      10-01-2018, 08:19 AM   #16
chris_flies
3027
Hmm. So, basically, when my injectors die, I can install S65 injectors, and then be ready for any extra power mods I might do in the future? Interesting...
      10-01-2018, 02:04 PM   #17
ornicar
ornicar's Avatar
Drives: 125i
Hi,
i believed that the N52 injectors pattern was really special & specicific, isn't it?
https://www.e90post.com/forums/showt...068208&page=20
Are the S65 injectors a real update for an Ethanol filled N52?
Thank you
      10-03-2018, 12:17 AM   #18
E30ROB
Originally Posted by ornicar View Post
Hi,
Thank you
Plug and play, I put 1500 miles on the car right after installing them without a retune, car adapted very well.
Since then I have put maybe 2500 miles on the car with retune and e85
      10-03-2018, 01:24 PM   #19
ornicar
ornicar's Avatar
Drives: 125i
OK
Thank you for your answer.
I see on ETKA that they are some Bosch (BOSCH 0280158164)
So the S65 injectors are probably the secret ones used on superchaged N52.
Good to know! maybe it is a little upgrade for E85 fuel.
"-Larger Bosch fuel injectors with identical spray pattern and angle as OEM to ensure 100% perfect driveability with valvetronic reduced valve lift."
https://esstuning.com/ess-n52-vt1-su...-system-gen-2/
      10-03-2018, 04:29 PM   #20
Taskmaster
Japan
2465
Why?
They run yes, but you should get a tune for them. They aren't the same.
      10-04-2018, 12:12 AM   #21
lowside67
Drives: 2011 BMW 128i
What other mods do you have? 3S or N54 intake manifold? Headers? Lightweight flywheel?
Thanks,
Mark
gotcha43149.00
      10-05-2018, 12:23 AM   #22
E30ROB
Why?
We checked the car on the dyno, AFR flat as can be and running safely. Going back for check up on dyno after installing catless resonated midpipe, new all four O2 sensors, plugs, and fluid flushes next week.
