06-13-2018, 02:55 PM | #1 |
Joint Chiefs of Staff
24095
Rep 190,633
Wagner Tuning EVO III COMPETITION INTERCOOLER Now Available *** New Product ***
Intercooler size 20"x12"x7.1" Intercooler weight 29 lbs Competition Intercooler Kit EVO3 for BMW E82 E90 The BMW Competition Intercooler Kit EVO III has the following core dimensions (510mm x 303mm x 180mm / stepped, 20.650cm³). The high performance intercooler core provides a 162% larger frontal area and 182% more volume compared to the stock mounted intercooler. Our engineers have increased the intercooler core size and efficiency, as well as improved the endtank design to remove any OEM bottlenecks, resulting in increased flow rating and charge cooling properties. We use our award winning WAGNERTUNING Competition Intercooler Core which is made specifically for this application. Constructed of the highest quality Tube Fin intercooler cores with inside turbulators combined with cast aluminum endtanks optimized by CFD for best possible internal airflow. The stock click connections have been eleminated and increased to a connection diameter of Ø70mm for In- and Outlet, so this kit comes with reinforced silicone hoses. The result is excellent cooling properties and a lot less pressure drop then the stock intercooler. Despite of it´s size the weight of the complete intercooler is only 13,2kg. This Intercooler Kit is the best choice when it comes to performance gains and low intake temperatures and also the right thing for racing. All of our intercooler use an anti corrosion protective coating with perfect thermal heat dissapating character. Optimal cooling with clearly more power. Kit is ready for installation, 100% perfect fit. Easy installation, only some little adjustments at the plastic cooler support are necessary. All of our products undergo rigorous quality control. The BMW Competition Intercooler Kit EVO III from WAGNERTUNING fits to the following cars with N54 & N55 engine:
packing list:
THIS ITEM CAN ONLY BE USED IN A COMPETITION RACING VEHICLE THAT IS NOT DRIVEN ON PUBLIC ROADS, UNDER CALIFORNIA STATE LAW IT IS NOT LEGAL FOR USE IN ANY OTHER MOTOR VEHICLE! Intake air temp control EVO III vs EVO II vs stock Pressure air drop More pictures of the intercooler
09-19-2018, 10:18 AM | #2 |
24095
Rep 190,633
