      07-22-2015, 09:59 PM   #1
E82MSport
E82MSport's Avatar
Drives: 08' Crimson 135i
Shadow Line Window Trim - Restore DIY EASY
I know there have been a lot of people unhappy with the condition of the Shadow Line trim around the window openings, so I thought I'd share a quick DIY to make it look new again.
I've been lazy and haven't done this but it will really only take you about 20 minutes to go from this
To this
All you will need is a microfiber towel and some medium cut compound. I used Meguiars Ultra Cut 105 but really any medium cut will work.
I applied a drop of compound to the microfiber towel and used finger pressure and moved in circles to achieve the desired results.
To show the difference I used a tape line.
Might be hard to see the tape line but in this image but you can see the difference.
It's as easy as that.
Hope this was helpful.
Ohlins Road & Track Coilovers / Apex ARC 8's 245/255-35 MPSS / Wagner Downpipes / Wagner EVOII Intercooler / ER Charge Pipe / Forge DV / PowerFlex RSFB / PowerFlex Differential Bushings / MFactory 3.46 Torsion LSD / MHD Flasher
dm87483.50
Matticus913476.50
      07-23-2015, 02:57 AM   #2
Esteban
Esteban's Avatar
Drives: a slow car fast
That looks really nice! You did a great job! Thanks for sharing.
      07-23-2015, 06:23 AM   #3
swagon
swagon's Avatar
Drives: F80 6MT
Pretty much what I did as well. Nice job.
      09-13-2015, 02:49 PM   #4
z0mghii
Drives: E82 135i
Got all this removed with this:
http://www.amazon.com/Meguiars-Mirro.../dp/B0002SQVX0
      09-14-2015, 08:09 PM   #5
mmmusty
Drives: 2008 alpine white 128i
I've tried a few products, and even let the car wash detail guys use their top of the line junk.... to no avail, hopefully this works.
Thank you!
      09-14-2015, 09:31 PM   #6
Pyrat 2
Pyrat 2's Avatar
Drives: Rapidly from A to B
I'll give this a try. For some reason my passenger rear trim is very bad and the rest is almost perfect. Very annoying as it looks way worse than your 'before' picture.
'07 Z4MR '22 GT4 '18 GT3 '16 GT4, '16 M2, '14 X1, '13 135is, '06 330i, '03 323 Ci, '01 330i, '99 M3 (RIP), '96 318is, some non-BMWs
      08-08-2019, 08:20 AM   #7
BimmerTy
///M
BimmerTy's Avatar
Drives: 2015 F15 X5 50i M Sport
Used the Meguiar's Ultra Cut 105 on my shadowline trim last night - worked like a charm. Went ahead an waxed the trim afterwards to keep it protected.
2015 F15 X5 xDrive50i - M Sport - Space Grey Metallic - 21" 612M - Accelera Iota ST68's - Black Dakota - Leather Dash - Poplar Wood - Ceramic - Shawdowline - Anthracite - Adaptive M - Full LED - Executive - DA+ - Surround - HUD - Enhanced BT - Soft Close - B&O - ACC Stop & Go - Multi Contour - 4 Zone Climate - Comfort Seats - Cold Weather - Muffler Delete - Akrapovic Tips - F85 Grille - 35% Tint - BMW All Weather Mats -- Missing DHP, NV, Active Steering, Rear Entertainment, & Cooled Seats
      08-08-2019, 08:58 AM   #8
Sam_M
Tea wot?
Drives: 2011 N55 135i 6MT
Nice, mine looks exactly the same.
Will try and cut it back when I next wash the car!
      08-08-2019, 12:17 PM   #9
Thunderguts
Thunderguts's Avatar
789
Drives: 2009 128i Sport MT
The only downside I see is similar to headlights. I would imagine that there is some kind of protective coating on the trim which is failing from sun damage. You're removing it all with the polishing compound which means it will happen again more frequently now. It's no big deal, but you'll probably need to repolish them every 6 months.
