05-21-2014, 08:59 AM | #1 |
Rep 2,696
FS: Forgestar CF5's 18x8.5 square setup
18x8.5 et45 wheels are in good condition. No curb rash on them and great looking finish. Currently wrapped in AD08's 235/40 all around. Tires are pretty worn and shot, TPMS for a 2011 and up is installed, however one sensor is failing. Asking $800 obo + shipping and any fees. The ad08's run very wide...wider than my pss 255's and there were no rubbing issues on a very low 135. It's tight...but good
05-21-2014, 01:22 PM | #2 |
Rep 246
very interested. What color and what fitment issues did you have. Fenders rolled camber etc... Thanks
Edit (found out they are red not a color that would work for me unless i could get them cheap enough to repowder coat.) Last edited by illiniwekchief; 05-21-2014 at 01:44 PM.. Reason: figured out color |
05-21-2014, 01:52 PM | #3 |
Rep 2,347
you shouldnt have to do anything major if your staying with a square set up with these ETs, If you roll the front and get some camber you should be able to do a 245/18/35 all around
Mods:-Berkexhaust -alpinaB3flash -CobbAP -Cobb FMIC -ER charge pipe tialQ bov -M3 front sway bar -M3 subframe bushings -M3 front upper and lower control arms -M3 guide rods -M3 rear upper control arms -Mfactory LSD -defiv lockdown kit -TC Kline SA coilovers /camber plates- HP rear toe arms |
05-21-2014, 01:55 PM | #4 |
Rep 246
I run 245/40/17 on 8.5 et40 currently so should not be an issue. I was a bit worried about the back.
05-22-2014, 03:13 PM | #6 |
Rep 2,696
Hmmm...there were pics here..but somehow they got removed. Let me see about adding them back in.
