      09-21-2020, 01:15 AM   #1
Intense_
Drives: 2011 BMW 135i
Intense Build Thread (1M Wide Body Conversion)
I've been lurking this forum for awhile now and decided that its time to start a build thread for my 1M wide body conversion. Its been about 4 years since I've owned it and I am still not bored with it. I LOVE THE DAMN THING.. to the point of spending $$$ to go wide body. Thanks to TUN3D, I have built the courage to start this project. I will document the cost and process in hopes that it will help someone else! I will be doing this conversion in phases.. starting with the front!
Current Modifications
2011 BMW 135i DCT
Performance
MHD Custom Tune (Full E85)
Pure Turbo Stage 1
Pure Turbos Inlet
Go Fast Bits DV+
CP-E Charge Pipe
Evolution Racewerks Competition Series FMIC
Helix Overdrive HPFP
Fuel-IT Walbro Stage 2 LPFP
Fuel-IT Ethanol Line Kit
VRSF 3.5" Catless Downpipe
Stock exhaust with resonator delete
Transmission
M4 Flywheel
Suspension
Stock.. but not for long
Front
41-35-8-052-625 Side Panel Front Left
41-35-8-052-626 Side Panel Front Right
51-11-8-057-717 Trim Cover Bumper Primered
51-75-8-051-609 Under-Hood Shield
61-67-8-051-590 Washer Fluid Reservoir
51-11-7-900-764 Screen
51-13-8-051-817 Left Base
51-13-8-051-818 Right Base
51-74-8-051-605 Air Duct Engine Oil Cooler
51-74-8-051-606 Air Duct Engine Oil Cooler
51-71-8-051-591 Cover Wheel Housing Bottom
51-71-8-051-595 Cover Wheel Housing Front
51-71-8-051-596 Cover Wheel Housing Front
51-64-8-051-988 Headlight Bracket Right
51-71-8-051-592 Cover Wheel Housing Bottom
51-64-8-051-987 Headlight Bracket Left
Subtotal: $2,146.22
Estimated Shipping via Freight Shipping: $226.56
Paint at local shop: $800
Total: $3,172.78
houtan707.00
Petro135452.50
uzone0212.00
      09-21-2020, 01:23 AM   #2
Intense_
Some pictures of my 1M goodies
      09-21-2020, 02:14 PM   #3
dtla1
dtla1's Avatar
828
Drives: 2011 135i, Space Grey
Are you planning to do Pure Stage 2 down the line?
I didn't think upgraded HPFP was needed for Pure's Stage 1 power, or the M4 Flywheel either? Maybe just for reliability?
BTW, would be cool to see and hear your story when the car is done. I grew up in Oxnard and still have family there so I'm down there every once in a while.
      09-21-2020, 02:53 PM   #4
Intense_
Eventually I’ll go stage 2. However, im having a blast with the stage 1. Upper rpm around 17psi is a huge difference. I went E85 because 91 in California is garbage. Definitely more power with e85 than 91 acn. I upgraded my flywheel because my transmission was already being pulled to fix my DCT pan leaks. That way if I go high hp I’ll have a flywheel that can handle it. I sourced a low mileage one for cheap.
When you are in town let me know!
      09-22-2020, 12:49 AM   #5
Intense_
Paint work done! $800 for bumper and two fenders.
      09-22-2020, 11:33 AM   #6
Intense_
So..... sold my Volks to get new wheels. Decided to go with the Apex EC-7R in brushed clear!! I want to change it up from the whole dark theme and of course I need to go more aggressive with the conversion.
      09-22-2020, 11:37 AM   #7
..Rush..
..Rush..'s Avatar
Drives: AW E88
Living vicariously through you guys!
Keep up the great work on you build!
      09-22-2020, 03:56 PM   #8
Intense_
Thank you! I was once in your shoes..
      09-22-2020, 11:44 PM   #9
sam-vr6
Drives: e46 M3
Amazing build. Great work.
Planning something similar. The 1M track width is approx wider by 7.1 cm front & 4.4 cm rear. (Info from www.ultimatespecs.com) compared to the non 1M body.
So inspite of installing OE 1M body panels, with the stock 135 suspension. The overal all track width will still be lesser than a 1M?
Do you plan to install M3 wider arms or use appropriate offsets on the stock 135 suspension to fill up the 1M arches?
Thanks in advance.
Sam
      09-24-2020, 10:47 AM   #10
Intense_
Thanks in advance.
Sam
I just copied the 1m wheel specs but in 18s instead. I know the rear is actually about 10mm more out which should be fine. Depending how the front is I'll throw on a spacer. I have stud conversion kit already. Don't plan on overhauling my suspension to 1m/m3 bits just yet.
      09-24-2020, 10:55 AM   #11
Intense_
Got some work done! Everything went smoothly until I realized I was sent two right side headlight brackets... the strange thing is that it has the correct part number for the left bracket. still need to tweak the fenders for gaps and body lines.
      09-24-2020, 11:19 AM   #12
Intense_
Drilled out the horn bracket and relocated the horns with a bracket from Home Depot. Had to make the hole bigger to fit the horn with a 21/64 drill bit. I also removed the headlight washers and capped off the pump with some plugs from AutoZone. Didn't want to remove the pump and have a connector dangling there. I've already coded out the headlight washers.
      09-24-2020, 01:49 PM   #13
Intense_
So I'm comparing the 1m headlight bracket to the 135i and it looks identical except for where it attaches to the fender. It's just cut off? I think I can modify my original and call it a day.
      09-25-2020, 07:25 PM   #14
Yeineken
Yeineken's Avatar
Drives: '11 135i M Sport
'11 135i  [8.20]
'16 Ford Hatchback  [0.00]
'15 X5  [10.00]
Looking good! Did you have any trouble ordering body panels with everything going on? I need to finish my car at some point and need to order the 1M rear bumper and arches.
      09-25-2020, 11:08 PM   #15
Krisryanl
Krisryanl's Avatar
Drives: 2012 BMW 135i
How did you manage to pay only 800 for all the paint work
      09-28-2020, 05:13 PM   #16
Intense_
No issues with ordering parts. Everything came in fairly quick. Only had one mistake with the headlight bracket but I was able to modify my stock one to work. As for the paintwork I have a local shop that I'm close with they were able to help me out a bit. $800 was just for the front end. Front end is complete! Just ordered my rear end conversion parts and decided to go with Jay Meadows fender flares. I'm all for saving some money.
Yeineken1300.50
Petro135452.50
      09-28-2020, 08:28 PM   #17
Raularango
Raularango's Avatar
19
Drives: bmw 135i
Is that oem from bmw ? I'm looking for that do you have the part number
Raularango
      09-28-2020, 08:36 PM   #18
Raularango
Raularango's Avatar
19
Drives: bmw 135i
Where did you get it painted?
Raularango
      11-15-2020, 07:06 PM   #19
Intense_
Just dropped off the car at DTM autobody to finish up the rear end!
      12-11-2020, 10:00 AM   #20
Raularango
Raularango's Avatar
19
Drives: bmw 135i
Bmw gang
Fenders are sick did you get your car painted in California I got new rear bumper I want to install but I need it painted first
Raularango
      12-14-2020, 09:39 AM   #21
Gray_Panther
Gray_Panther's Avatar
1555
Drives: 128i
Nice, how long will they take and any updates?
      10-30-2022, 12:15 PM   #22
sims_drk
Morocco
Drives: Bmw 135i
Hello im working on a same project and love what ur doing . Will it be possible to fit 19 csl replica with an offset of 27 at the rear ?
