      09-03-2023, 12:59 AM   #1
JupiterBMW
Self Proclaimed Roundel Junkie
JupiterBMW's Avatar
Drives: '11 E90 M3 & '13 F25 X3
My 1M3 track toy.
I picked this car up about 6 months ago to turn from a really great street car into a REALLY fun track toy. I am by no means a competitive racer, and I'm even less committed at keeping up with build threads... You've been warned.
If you've been online for a while you might've seen this car on Built for Backroads... Ironically, the car is somewhat 'related' to my E91, shown in the last photo. That car can be viewed at the link below:
https://www.builtforbackroads.com/li...-328i-n54-swap
Anyway, I saw all of the great threads of everyone detailing their builds, and figured I'd do the same. I'm just getting started so feel free to read along.
The Car
2013 135i, M-Sport
Carbon Black/black interior
S65 4.0 V8, DCT (E9x M3 GWS)
Full M3 running gear including driveline, subframes, brakes, suspension, etc.
Mods
-Style 313 wheels (18")
-M2 Comp heated seats
-Dinan E82 135i exhaust (custom 2-1 midpipe)
-do88 Aluminum radiator
-Ohlins 'Dedicated Track' Coilovers (Vorschlag camber plates, Swift springs)
-Turner Tracksport E9x M3 2 piece rotors
-Goodridge SS brake lines
-PFC 11 brake pads
-Hard Brakes titanium pad backing plates
-Castrol SRF fluid
Ready to install
Apex SM-10 wheels, 18x8.5 ET35 square
Kumho V730 tires, 255/35-18 square
I'll try to keep up with this, and I love reading everyone else's threads for ideas and inspiration!
2018 F15 X5d Carbon Black/Nutmeg Individual- Oil Burner Tow Rig
2013 E82 1M3 Carbon Black/Black- S65/DCT Track Toy
2013 F25 X3 35i Alpine White/Chestnut- German American Family Hauler
Past: '11 E91 335is, '11 E90 M3, '10 X5M, '14 328d, '03 330i Dinan3 ZHP, '04 330i ZHP, '12 X3 35i
Appreciate 8
      09-04-2023, 04:30 PM   #2
Brian_
Drives: '11 128i, '18 VW Golf
2011 BMW 128i  [0.00]
Awesome to see an S65 swapped E82 getting tracked. Definitely curious how well that wheel/tire combo clears everything, seems like a pretty aggressive wheel setup for non-stretched tires.
      09-04-2023, 04:51 PM   #3
lforter
Drives: 135i?
This is crazy, how do you feel the e82 behaves with the s65? We need some engine bay pics...
      09-05-2023, 08:44 AM   #4
amg6975
amg6975's Avatar
500
Drives: '12 M1.5, '05 ZHP, '98 M3/4/5
This is so close to my car's twin! SM10s and all.
      09-06-2023, 09:15 AM   #5
JupiterBMW
JupiterBMW's Avatar
Wheel/tires will clear just fine. With the E9X M3 rear end, I gained 10mm of clearance, so that helps. I currently have 255/35s on the back on the same size/offset wheel and no issues. I swapped them up front for a bit of driving to verify the clearance up there, again, no issues. Excited to get it on and get it on track again.
I have no basis as its the ONLY way I've tracked the car, but doing some reading from others with more experience, they say this is a more appropriate weight distribution up front due to the shorter/wider engine, spreading the weight out a bit more. Apparently it also sits a little further back than the inline engine, helping to bring the weight more towards the center... Pics soon, I need to get it cleaned up for that!
Share some photos! I went for race silver in the wheels, you..?
Brian_10.50
      09-06-2023, 03:04 PM   #6
amg6975
amg6975's Avatar
500
I would not say "just fine" They rub a lot. I have -3.5* of camber in the front and -2.5 in the rear with 245/40R18s and had to do a lot of pulling.
The car is a whole different animal. It's probably not any faster in a straight line but the torque curve and how the weight feels is a massive difference.
Same.
      09-06-2023, 03:10 PM   #7
amg6975
amg6975's Avatar
500
OP, I'm curious what you did about the oil cooler. I've seen 1M clones swapped that say it fits but I could not get the M3 oil cooler to fit behind the 135 bumper no matter what. I ended up having to make a custom solution.
      09-06-2023, 05:52 PM   #8
JupiterBMW
JupiterBMW's Avatar
Wow, we have a lot to chat about... Your car looks great btw! Sending you a PM to share contact info, would like to chat about things..
      09-07-2023, 11:44 AM   #9
spidertri
spidertri's Avatar
Drives: 11 128i 6MT Sport
Man, SM10s look fantastic on these cars, that's awesome.
OP and AMG, how is the power delivery with just running a 245/255 in the rear? Do you have to feather the throttle coming out of a corner to make sure the rear end doesn't step out too much? Have you considered going to a staggered setup to get a 265 or 275 in the rear?
11 128i slicktop
13 WK2
19 Alltrack S
amg6975500.00
      09-07-2023, 02:02 PM   #10
amg6975
amg6975's Avatar
500
Never a problem that I've come across. I had the same fear but it hooks and goes way better than I would have expected. I can get on the power the same place an E92 I've come across does. Here's a lap of WGI (with poorly synced audio) on 200TW Continentals which are not a particularly sticky tire.
Never considered not running square. The ability to rotate is way too valuable for a track car. Although I will say my car wears tires extremely evenly front to back.
      09-07-2023, 10:26 PM   #11
fe1rx
Drives: 135i, 328i, Cayman S
Your very smooth driving can take some of the credit! Your car looks very well sorted and sounds great.
amg6975500.00
      09-08-2023, 04:59 AM   #12
JupiterBMW
JupiterBMW's Avatar
spidertri - I have to agree with AMG on this one. Currently, my car has a 255/35-18 and 225/40-18 Michelin PS4S setup, and there is absolutely no issue with power delivery that I've noticed. Given the low torque of the S65, I think a 255 is more than enough for the track. I definitely was pushing the front end around a lot with the smaller fronts, but I'm getting ready to install a 255/35 square setup, Kumho V730s. I am very excited to give this a go and see how it does, I'll be on track again on the 21st, Daytona Speedway.
      09-08-2023, 06:00 AM   #13
spidertri
spidertri's Avatar
That's really interesting, like you say, the lower torque of the S65 and linear power delivery probably makes it very manageable. That's super cool. I totally agree that you need to be able to run a square set up at the track to really get the most life out of the tires.
255 V730s are what I'm currently running, coming from RT660s, I like them a lot. The sidewalls are much stiffer and I prefer that feedback over the 660s. I think you'll enjoy them.
11 128i slicktop
13 WK2
19 Alltrack S
      09-08-2023, 06:38 AM   #14
JupiterBMW
JupiterBMW's Avatar
Excellent, great to hear. All of my track buddies have lots of different opinions, but the 730s seem to be one of the favorites for lap times. A couple of the guys recently tried out a set of the new Conti EC Force tire and were definitely not as happy, more of an endurance tire than a hot lap tire... Just FWIW..
      09-08-2023, 08:17 AM   #15
amg6975
amg6975's Avatar
500
Interesting. I have a set of Supercar 3Rs on order but I don't know if TireRack will get them before I need them so I'm trying to come up with a plan B. I ran the RT660 before the Continental and really liked them but was looking for something a step above those. I was thinking RE71RS but they can only tolerate a couple laps before overheating which I hate. V730 on the short list of options.
      09-08-2023, 09:12 AM   #16
spidertri
spidertri's Avatar
When I first got the V730s installed I didn't think they had the outright pace of the RT660 but since then I've been resetting my personal best at each track I've been to, maybe just adapting to the driving style this tire needs? The feel of the V730 is similar to the RE71R I had prior to the RT660 and they last an entire 25min session without getting greasy. I really like them.
11 128i slicktop
13 WK2
19 Alltrack S
      09-08-2023, 11:14 AM   #17
JupiterBMW
JupiterBMW's Avatar
And you simply cannot beat the price point. They’re obscenely inexpensive.
      12-28-2023, 02:11 AM   #18
JupiterBMW
JupiterBMW's Avatar
Finally an update... There have been a lot, so I'll just make a few posts about what I've been up to. Since my last post, I've had the car at Daytona, Sebring, and Homestead. 4 track days in the last few months... A few upgrades...
First up, new wheels/tires. As mentioned above, a square set of 18x8.5" Apex SM-10 and Kumho V730s, 255/35-18. While I was doing this, I also installed a set of Bimmerworld bulletnose "race" studs. Everything fit perfectly, did a few more tweaks to the coilovers, but otherwise super happy with them. I do find them getting a little slippery now, but I think its likely due to them having 4 days on them already. I'd like to do some fender pulling as well and see if I can squeeze a 9" wheel and a 265 on there. We shall see.
      12-28-2023, 02:26 AM   #19
JupiterBMW
JupiterBMW's Avatar
Next up was to start tackling some DCT overheat issues. So, I opted for the do88 DCT cooler, a fantastic upgrade. Of course, the carbon duct that comes with it is intended for the E9x M3, so it doesn't fit our front bumper. I managed just fine without it, no more DCT temp issues.
      12-28-2023, 02:55 AM   #20
JupiterBMW
JupiterBMW's Avatar
Nest up was a healthy interior upgrade. After running Daytona and seeing the speed attained on the banks, and then hearing of a fatality there a few weeks after, I realized I need some safety upgrades. So, I did a rollbar from Streetbully Fabrication (look him up on Instagram), Sparco QRT-C-X seats, VAC hard mounts, Sparco QRT side rails, and OMP Versa 2 6-point harnesses. The install of all of it was great, no issues to speak of.
While I was doing this, I did some electronics as well. Nothing crazy, but I ran a few long USB-C cords for GoPro power (passenger side upper windshield corner and another on the rollbar up top), and also installed a Garmin Catalyst. For those of you that haven't used one, it is a fantastic tool!
Here's a few photos...
      12-28-2023, 03:17 AM   #21
changster
Drives: BMW E82 1 Series M Coupe
I love how that do88 DCT cooler is being used on the 1 Series.. I’m doing the same as an upgraded engine oil cooler on my 1M.
      12-28-2023, 08:51 AM   #22
JupiterBMW
JupiterBMW's Avatar
Yes, I actually just saw you were using it as well, its such a great upgrade! I still have to upgrade the engine oil cooler, but I'm using the factory E9x M3 cooler, and the do88 upgrade won't fit. Likely going to set up a custom cooler from Setrab at some point.
