10-18-2016, 05:47 PM | #1 |
Supreme Allied Commander
3814
Rep 54,307
Drives: F80 M3
Rogue Engineering Monoball Front Tension Arm Bushing (E9X, E82, F8X, F2X, F3X)
The Rogue Engineering Front Tension Arm Bushings replace the factory rubber bushings with ball joints and machined aluminum housings. By eliminating the inherent flex of the rubber bushings, responsiveness and steering precision is improved while reducing brake shimmy. The ball joints feature rubber boots to keep out dirt and road debris from contaminating the bearing.
The Rogue Engineering Front Tension Arm Bushings benefits include: Made in USA, 6061-T6 CNC'd anodized aluminum 303 Stainless steel inserts OE Grade Ball Joints for quiet operation Improved steering responsiveness Reduced brake shimmy (especially for those at the track and/or using big brake kits) Sold as a pair. This product fits the following vehicles: E9X M3, including Coupe, Sedan and Convertible E9X 3-series with E9X M3 front tension arm retrofitted E82 1 M Coupe F8X M2/M3/M4 F2X 228/230/M235/M240 F3X 328/330/335/428/430/435/440 Order here: http://www.hpashop.com/Rogue-Enginee...?categoryId=-1 Last edited by HP Autosport; 02-05-2018 at 10:12 AM.. |
