06-17-2018, 10:35 AM | #1 |
Needs a long road trip...
347
Rep 527
128 water pump life span
It seems in reading the forum that the 135 suffers from the water pump failing at around 60-80k miles. The lowly 128 doesn't seem to suffer the same fate. I'm right at 94k miles on my e88. I wanted to reach out to the 128 owners and ask one of two questions.
At what mileage did you have to change out the water pump? If you are still on the original water pump, what's your current mileage? I'm curious if anyone is over 100k on the original pump... Last edited by olds350; 06-19-2018 at 01:50 PM.. |
06-17-2018, 10:50 AM | #2 |
Rep 704
Currently on 54,000 kms and original pump.
From my understanding they are the same pump, but since there is less heat compared to the turbo guys (and having the pump running when the engine is off) the pump lasts longer. A few of owners replaced theirs at 60-80k miles, while a lot more users see 90K+. Personally i will replace mine at 80-100k if it did not fail already. |
06-17-2018, 11:03 AM | #3 | |
347
Rep 527
06-17-2018, 11:07 AM | #4 |
Malcontent
188
Rep 305
I bought my car with 103k miles and the original pump and thermostat. I changed them preemptively soon after I got the car.
Life's tough. It's tougher when you're stupid. -John Wayne
06-17-2018, 11:09 AM | #5 |
Rep 143
I'm contemplating a change at 50-60k miles.
I suspect it not the miles as much as the driving conditions. My commute home is 25 miles of crawling stop start traffic, (90+ minutes), which, during the summer in Atlanta, gives the cooling system a workout. |
06-17-2018, 11:43 AM | #6 |
Rep 439
Mine went out at 139k km or 86.3k miles, water pump and thermostat was replaced
2008 SGM 128i - 3 Stage IM - 130i Tune - Dinan Camber Plates - BMW PE - Injen Intake - 1M Mirrors - LCI Blacklines - M4 Spoiler - Blacked 263's - Aero Bumper - Aero Side Skirts - OMGSplitter - AFE Intake Scoops
06-17-2018, 12:05 PM | #7 |
Rep 2,267
it doesn't matter if it's a 128 or 135 or a 118 for that matter. it's an electric water pump used by BMW....they fail at around 60-80k miles VERY OFTEN. get it changed....
06-17-2018, 12:11 PM | #8 | |
Apprentice
373
Rep 801
It's really not a consistent mileage where it goes out but more often then not it will go between 65k - 100k. I knew it was going out because on short drives, the radiator fan was on full blast working hard. So if you hear your fan working extremely hard when your barely driving, that's a good indicator your pump is going out but that doesn't happen all the time. Just do one of two things: 1. Get it replaced 2. By the parts ahead of time It's not if, but when it will go out. |
06-17-2018, 04:41 PM | #11 |
Rep 406
Drives: S54/N52
108k on original pump.
No excessive fan, no abnormal readings on WP parameters when monitored via Carly. |
06-17-2018, 05:27 PM | #12 |
Sideways and Smiling
3027
Rep 2,860
Drives: In Exuberance
Carfax didn't say anything when I bought it about the water pump being replaced, but, bolts holding it in look newer than the other bolts near them, so it was probably replaced. 174k miles and is only gone through one, just waiting for the inevitable now...
06-17-2018, 07:45 PM | #13 |
Bergspyder
1464
Rep 1,210
FCP euro does a good job on pricing and lifetime warranty.
06-17-2018, 10:02 PM | #14 |
Rep 2,051
About to hit 125k miles on the original pump and my plan is to not worry about it. Its looking like a hot summer though. Hopefully it won't be an issue.
06-18-2018, 08:26 AM | #15 |
Rep 30
My '08 128 with 92k miles still has the original. I am in the process of replacing my radiator with an all aluminum one due to a leak at the top elbow. Also going to replace upper, lower hoses and the one to expansion tank.
I have also been replacing the coolant every two years since I bought it new in 08. |
06-19-2018, 12:10 PM | #17 |
Rep 1,075
Mine failed at 52k (135i).
I was going to replace it at 60k pre-emptively but never got that far. Its bone stock, never tracked and generally babied. Problem is that there's virtually no warning and it leaves you high and dry when it craps out.
2012 135 Convertible 6MT
2017 Acura MDX |
