      06-24-2014, 04:16 AM   #1
1M Chum
1M Chum's Avatar
Singapore
Drives: 2011 1M Alpine White
2011 BMW 1M  [0.00]
Brake pad upgrade? New discs installed!
Lately I was experiencing vibrations under braking especially after a wash (where the calipers initially 'stick' to the disc) until force is applied under acceleration
Recently though the issue has been worse - and I would expect this to diminish after some brake use. Took the car back and it turns out the rear discs were warped - which explained the vibration. The car is under warranty so the discs will be replaced - but the car will be heading to the track soon - and I have read that the OEM brakepads really aren't good enough.
Suggestions? No other mods to the car...
Cheers
///1M - DUCATI 1199s - KTM 690 SMCR
      06-24-2014, 08:32 AM   #2
MPoweRo
MPoweRo's Avatar
Drives: F82 M4 ZCP LCI2 M, G05 X5 40i
Endless ME20. Best pads I've ever used.
M4 Times (PSC2): Sandown: 1.21.76 Winton:
1M Times (PSC2):
Phillip Island: 1.53.09 Sandown: 1.24.03 Calder Park: 1.07.31 Winton: 1.36.71
      06-24-2014, 08:53 AM   #3
1M Chum
1M Chum's Avatar
Singapore
2011 BMW 1M  [0.00]
Thanks Ro1M, I'll check then out. Never heard of Endless - was told to check out EBC Yellows too...
      06-24-2014, 12:20 PM   #4
Splinterz88
Splinterz88's Avatar
Drives: BMW 1M
2011 BMW 1M  [8.86]
You can also try Performance Friction #08 compounds. An endurance pad that will last a while. I would also upgrade the brake fluid to a high boiling temp one, Motul RBF600, or the likes and you will be good to start with.
#446 of 740
      06-24-2014, 12:47 PM   #5
lcrain
Drives: e36 m3, TT-RS
Don't use the EBC Yellows. Marginally better performance than that stock pads and they are much noisier. Stay away.
I enjoyed PFC pads for the track. Had great results with the 01 compound (amazing initial bite), but they didn't last as long as I had hoped.
      06-25-2014, 05:59 AM   #6
MPoweRo
MPoweRo's Avatar
I've used several brands and these are my favourite.
Company: http://en.m.wikipedia.org/wiki/Endle...hnology_Europe
ME20s:
http://www.1addicts.com/forums/showthread.php?t=779535
http://alekshop.com/products/endless..._e92_m3_e82_1m
Can't get them to fade!
1M Times (PSC2):
      06-25-2014, 08:09 PM   #7
Nugget
Nugget's Avatar
650
2011 BMW 135i  [10.00]
Originally Posted by Ro1M View Post
I use ME20s on track with my Stoptechs, can't get them to fade either. Awesome pads.
      06-25-2014, 08:29 PM   #8
1M Chum
1M Chum's Avatar
Singapore
2011 BMW 1M  [0.00]
Ok that's great - Thanks for the info - now to find where I can get them.... As usual stock here of anything is limited (at best, and that's if they even stock them here) so google here I come
      06-25-2014, 09:22 PM   #9
Nugget
Nugget's Avatar
650
I bought mine from an Australian distributor so can't really help, but they usually take a while as they were made to order in Japan.
      06-26-2014, 06:35 AM   #10
1M Chum
1M Chum's Avatar
Singapore
2011 BMW 1M  [0.00]
An Australian distributor would work actually - I'm in Oz about once a month
      06-26-2014, 09:02 PM   #11
Nugget
Nugget's Avatar
650
Then call or email vsport.
I've always found them very helpful.
      06-30-2014, 07:28 AM   #12
1M Chum
1M Chum's Avatar
Singapore
2011 BMW 1M  [0.00]
Awesome - Thanks Nugget!
      07-01-2014, 12:53 PM   #13
Siddy
Drives: 2009 BMW 135I
EBC vs Hawks
Hi All,
Should I consider EBC( Yellow, Red) or Hawks HPS. Daily street driving with occasional track days during summer. Any suggestions please ?
Thank you,
Siddy
2009 BMW135i, Manual M-package
2009-BMW135i-Manual, M package.
      07-01-2014, 09:21 PM   #14
ayao
Thread killer
642
Drives: 1M
Originally Posted by Siddy View Post
Hi All,
Thank you,
Siddy
Ferodo DS2500 is considered a decent dual-use pad.
      07-02-2014, 12:50 AM   #15
M3 Adjuster
Albania
7906
Hi All,
Thank you,
Siddy
NO. I wouldn't use EBC anything. If you are in a Miata then perhaps, fine.
But not in a medium to heavy car. Just don't waste your time or money.
The stock pads are very much up to the task of track duty, for beginner to intermediate level track drivers. A stock type replacement pad that is a little more aggressive is the Performance Friction Z-rated pad. Perhaps the Hawk HPS fits here.. I have not used it.
As others have mentioned, the Ferodo DS2500 is a good pad for the intermediate level track driver that doesn't want to go full race pad and doesnt want to change from street pads for the track. The Hawk HP+ is also a decent combo pad as well. This driver typically will be running street tires or max performance tires like the Hankook RS-3, BFG Rival, Advan AD-08, Dunlop Direzza Star Spec and may also be an autocrosser. Keep in mind that you will likely get some squeal from these pads on the street. Braking in shorter distance , and *harder*, on the street will help save your ears and keep those odd looks from other drivers to a minimum..
Advanced level drivers on full race tires will eventually go with true race pads like the PFC 08 or 11, Hawk HT-10 or DTC, Ferodo DS3000 etc. Those in truly hot climates (Texas, Arizona, California, Australia) can run these pads on the street (of course not during " winter") at the risk of worn out ear drums due to impersonating a dump truck at every corner. Braking performance on track of course will be phenomenal.
My absolute personal favorite pad is the PFC. In my opinion they provide 85-90 percent of the initial bite of a Hawk Pad with better torque and modulation throughout the pedal range. Hawk pad lovers will forever be addicted to Hawk's killer initial clamp down force, so Stay with hawk if that is you o "King of the late brakers... " While I do like the HT-10s, I prefer a pad that gives me even * more* braking torque as I need it when I need to *really* squeeze on the binders at the end of a braking zone, so the PFC pads are my favorite. I am curious about the Endless pads the Aussies have access to but nothing else compares to PFC 01, and 08 in my book.
      07-02-2014, 08:01 AM   #16
MDORPHN
Drives: AW 1M
Great post by Mark and agree with all of his observations.
Of course, I'm also a PFC fan.
BTW, the PFC-01 -- a truly phenomenol race pad -- is being phased out in favor of the new PFC-11.
Neil
      07-02-2014, 10:14 AM   #17
MJockey
Drives: e36 M3, e82 1M
As a 11 year track day veteran, I agree almost 100% with this post.
Many years ago I put a set on EBC yellows on my wife's Eagle Talon for her first track day. They didn't last the weekend. I had to go back to a stock pads just so she could finish the weekend. Hawk HPS are a great street pad but they are not intended to be used on the track. If this is your first track day ever, then you should be ok with stock pads. After that I would recommend one of the dual purpose pads that M3 Adjuster mentions above.
