08-10-2018, 09:08 AM | #1 |
Rep 3,722
DIY Catless DP, Success!! Straight piped N55
After this fiasco: https://www.1addicts.com/forums/show....php?t=1523868
I ended up taking the car to friend to help get the DP out since the studs were such a problem. After lowering the subframe, hitting the studs with an acetylene torch & air hammer, and some drilling with a hole saw....... 20180809_171425 by Matt Steele, on Flickr I can see the light!!!! 20180809_172900 by Matt Steele, on Flickr Hmmmmm something missing here....... 20180809_181401 by Matt Steele, on Flickr 20180809_181411 by Matt Steele, on Flickr Quick cold-start teaser before I get some better footage with a real camera. This is with the cutout open, so other than the resonator in the N55 mids, it's basically a straight pipe! 20180810_085838_1 by Matt Steele, on Flickr
"Tobias" 2013 135i ///M-Sport 6MT • Pure Stage 1 • XDI 35 HPFP • 404whp/440wtq |
08-10-2018, 03:19 PM | #2 |
Rep 545
Sounds sick! Out of curiosity, how hard was it to knock the guts out? I tried to do it on one of my old trucks with a piece of pipe and a BFH and didn't have any luck...looks like it must not have been too bad on the 1er?
2011 BMW 135i ///M-Sport, DCT
Bilstein B12 kit, Dinan camber plates, M3 front control arms, Whiteline poly RSFB, MHD Stage 1, cp-e Charge Pipe, H&R Front sway bar, BMW performance diffuser |
08-10-2018, 03:29 PM | #3 |
shmo
383
Rep 1,026
so piped fro mthe dp to the mids?? then from mids u took out the packing on the stock muffler??
any reason why u didn't go 3 inch from the dp str8 to the rear??
No sig
08-10-2018, 06:48 PM | #4 |
Rep 727
08-11-2018, 09:00 AM | #5 |
I like turtles!
726
Rep 698
OP, don't know if you've lived with a catless car before, I did with my Evo and can tell you it isn't worth the trouble. The smell while sitting at a traffic light with the windows down is nauseating, and there really isn't much power to be gained (with the Evo it was 10whp, which is something you won't feel).
08-12-2018, 10:20 AM | #6 | |||
Rep 3,722
Not interested in replacing the N55 mids, not worth the investment. Quote:
Also there's a good bit of restriction from the N55 cats, and while the overall power increase might not be extraordinary, I certainly have noticed increased throttle response. All that aside, the sound alone is WELL worth it, I'm obsessed with the new tone and hearing the turbo spool up is amazing!
Tags |
cat, catalytic, catless, custom, diy, downpipe, n55, pipe, remove, straight |
