      05-19-2014, 03:26 PM   #1
nicoz
Drives: 1M
F80/82 M3/M4 wheels on 1M?
Hi,
Do F80/82 M3/M4 wheels fit on a 1M?
Thank you
      05-30-2014, 09:26 AM   #2
BB-Driver
Drives: BMW E82 1M
Yes but only with spacers
      06-11-2014, 05:59 PM   #3
HP Autosport
Supreme Allied Commander
Drives: F80 M3
Originally Posted by nicoz View Post
Hi,
Thank you
We will find out soon enough!
Have M3 coming and still have my old 1M(sold) at the shop.
      06-13-2014, 01:06 AM   #4
atl_1M
Drives: '11 1M, '20 X5 40i
Can anyone photoshop the new M3 wheels in black on a black 1M? Thanks in advance!
      06-13-2014, 10:29 AM   #5
flzrider
Drives: AW 1M
Be sure to post some pictures!
      06-14-2014, 11:08 AM   #6
Slow///1
Drives: F80, GT3, X7
I've got an M3 ordered and will try swapping at some point.
      06-30-2014, 07:38 PM   #7
Thibs
Drives: 2011 BMW 1M
I would like to see this as well.
      07-03-2014, 05:49 AM   #8
BB-Driver
Drives: BMW E82 1M
Any updates?
      07-03-2014, 08:57 AM   #9
Snertz
H O O N
Snertz's Avatar
Drives: ein M!
For style 437M 19s, fronts will sit 2mm further out, no mods needed. rears will fit 15mm recessed, run 15mm spacer to make it sit same as the stock 359M. Run 10mm front/25mm rear spacer to make the 437Ms sit flush on a 1M
If you run the flush setup, you'll likely have to go smaller tire width since stock F8X M3/M4 tires are 10mm wider than stock 1M, unless you don't mind rub at full lock or big compressions.
Same goes for style 513M 18s
U WOT M8?
      07-04-2014, 07:35 PM   #10
eeghie
Kind of a big deal
300
Highly skeptical of what somebody at the dealership told me today: the new M3/M4 (i guess the whole F80/F82 platform has a different bolting pattern (No longer 5x120)?
Can somebody confirm/dis-confirm the bolt pattern of the new F80/F82
(secretly trying to confirm whether the F8x ///M optional ceramic disk brakes will fit our 1M ...)
      07-05-2014, 06:31 AM   #11
mrphil
New Zealand
24
Drives: 1M
Still 5x120, here is all the specs on the new wheels
http://f80.bimmerpost.com/forums/sho...d.php?t=945713
      07-05-2014, 03:57 PM   #12
eeghie
Kind of a big deal
300
Pls also have a look at the brake disk and caliper geometry for interchange-ability (w or w/o adapter)
thx!
      07-08-2014, 02:01 PM   #13
Snertz
H O O N
Snertz's Avatar
Drives: ein M!
Right in a sense, the bolt pattern is still 5x120, but they went from 12mm to 14mm x 1.25 for the wheel bolts.
U WOT M8?
      09-05-2014, 06:23 AM   #14
BB-Driver
Drives: BMW E82 1M
Up! i want see pix
      01-28-2015, 01:51 PM   #15
BB-Driver
Drives: BMW E82 1M
Finaly i put today the M437 Wheels on my 1M
      01-28-2015, 02:11 PM   #16
flzrider
Drives: AW 1M
Awwww, you gotta post more pics than that!
Side question: do the 1M's 12mm wheel bolts fit loosely in the 14mm opening of the M3/M4 wheels?
      01-28-2015, 02:12 PM   #17
MrRoboto
Drives: VO 1M
More pics please!!
      01-28-2015, 02:46 PM   #18
BB-Driver
Drives: BMW E82 1M
yes they fit, on sunday i will post more pictures
      02-01-2015, 10:38 AM   #19
BB-Driver
Drives: BMW E82 1M
New pictures for you
      02-01-2015, 10:58 PM   #20
nachob
I think the new F80 18s are best looking BMW wheel I have seen in years.. Stunning! If i get another 1M, I would love to have a set of those. Anyone else try them on 1M?
      02-02-2015, 01:09 AM   #21
BB-Driver
Drives: BMW E82 1M
Update
      02-03-2015, 02:47 PM   #22
Yeineken
Yeineken's Avatar
Drives: '11 135i M Sport
'11 135i  [8.20]
'16 Ford Hatchback  [0.00]
'15 X5  [10.00]
Not bad looking. Still prefer the OEM wheels for the 1M.
Paco1M101.50
