02-07-2008, 07:15 AM | #1 |
Rep 265
Comfort Access-- additional benefit(s)
A "benefit" to having comfort access that I have not heard mentioned are:
I know this is frowned upon, but you can start the car COLD days, get out and LOCK the car. Then go inside while she warms up. With the base key fob, the car will stop when you try to remove the fob from the dash. Although I have not tried it, theoretically you should not be able to lock your keys (the key fob) in the car. With the basic key, unlock the truck, set you stuff in the car, INCLUDING the fob, then close the truck.. Key is now locked in the trunk. With CA just touch the trunk to open.... Anyone think of other benefits? |
02-07-2008, 07:22 AM | #2 |
Rep 10,176
You can also do that on non-comfort access cars.
I can start my car with fob, stop car, remove key, start car again (with no key inserted), open the door and leave the car with the key in hand. |
02-07-2008, 03:11 PM | #4 | |
Throbbing Member
43
Rep 1,433
Remote start wouldn't make sense for manual transmissions, of course.
2014 Tesla Model S 85kwh
Previous cars: 2011 335d / Deep Sea Blue / Saddle brown / sport / premium 2008 BMW 135i / 6MT 2002 Z06 Corvette |
02-07-2008, 03:18 PM | #5 |
1er
73
Rep 1,205
02-07-2008, 03:56 PM | #6 | |
Rep 98
I know I'm new here, but I thought, in the past, I have read on the 3-series forums (E90post I think) that with Comfort Access, if you try to lock your keys in the trunk, the trunk will not latch and stay popped open. Is that not how it works on the 1er as well?
I have had a remote start on a manual transmission before. You have to "arm" the system when you leave the car. 1. Pull up and park where you are going to park it, leave car in neutral while car is running. 2. Pull hand brake. 3. Turn off ignition (car will continue to run, however, so you have to sacrifice valet key or have bypsass). 4. Without pressing the clutch, handbrake, or anything else, climb out of car. 5. Upon shutting door, car will turn off and alarm will engage. This whole process ensures that you did not leave your car in gear or something so it'll be safe to start. If you open your door or unlock the system at any point after that, the system will "disarm" and you won't be able to remote start it the next time, because there's no guarantee the car is the same as when the system armed. Quote:
02-07-2008, 04:00 PM | #7 |
Rep 308
02-07-2008, 09:49 PM | #9 |
Rep 1,000
Get out of car. Touch top of handle. Sunroof shuts. Windows roll up. Doors & trunk lock. Pretty cool...Arrive at hot car. Press unlock on remote. Doors unlock. Keep pressing. Windows roll down. Sunroof opens. Heat escapes. Very cool...Open door. Start car. Drive away. Key in pocket. Super cool....($500?)
02-07-2008, 09:59 PM | #10 | |
Rep 45
02-07-2008, 10:28 PM | #12 | |
Rep 104
If you lock the car, then open the boot/trunk and place the key in there and then close it, the car will flash the hazard lights quickly (about 3 times from memory) and then pop the boot/trunk open again. Be warned, this does not work if you leave the key inside the passenger section. You can lock the key inside the car accidentally, but you have do do the following: - have a door other than the driver's door open - lock the car (with the fob or comfort access) - toss the key inside - shut the door Now you'll need your other key!! Paul Martin |
02-07-2008, 10:39 PM | #14 |
Rep 104
Sure you can, but you can also lock the keys in the trunk/boot without comfort access.
Just pointing out that you can still get into trouble with comfort access, despite it preventing you from locking the keys in the trunk/boot, although you have to try pretty hard! :wink: I just tried it as an experiment. Paul |
02-09-2008, 08:21 PM | #15 |
Rep 21
On the E46, I think the window/sunroof open/close sensor was IR and on the door handle. It was useless because you usually had to be within 15 feet of the car for the feature to work. You feel like a real winner standing right in front of your car holding a button while your windows slowly lower (don't open door... stops procedure, don't let go of button either).
Does Comfort Access do this via RF, and is the standard system RF or IR? |
02-09-2008, 09:14 PM | #16 | |
Rep 104
The range was smaller than expected partly due to the low power output of the transmitter, with its built-in rechargeable battery. The receiver is part of the rear windscreen demister (as it is for the radio). The signal booster box is in the left hand C pillar - pull it off and you'll see :biggrin: The 1er also uses RF transmitters and the range is not much greater, with or without comfort access. With comfort access, the fob contains a removable, non-rechargeable battery. Without comfort access the fob contains a rechargeable Li-ion battery which recharges by induction when in the dash (just like the E46 key fobs recharge). The 1er that I have (hatch with comfort access) has 6 RF transmitters in the car to sense the key when it is in close proximity to the car. Two for each front door (one inside, one outside) and two for the boot/trunk (one inside, one outside). This is how it can not only tell if the key is inside the car or not, but also which door you're standing at: If you stand at the driver's door (with the key) and someone tries to open the passenger door, it won't work (and vice versa). Hope this helps. Paul Martin |
