      04-03-2013, 12:25 PM   #1
turbo1
Drives: 2011 135i Msport
Throwing codes.. HELP
gents,,
i keep ketting these two code:
P2D61 and P2C58
and a half engine light... car drives fine but no boost...
      04-04-2013, 07:02 PM   #2
turbo1
i believe the code meanings are:
2d61 - throttle valve, monitoring
2c58 - charge air pressure, deactived
im pretty sure 2c58 is the limp mode, deactivating boost because of the other code... what to do?? is it VANOS related?
      04-05-2013, 06:51 AM   #3
JimD
JimD's Avatar
368
Drives: 128i convertible
I guessing but you might find this helpful:
http://www.ehow.com/about_5865341_th...-problems.html
Jim
      04-05-2013, 12:49 PM   #4
turbo1
Jim
jim, thank you for the response... upon further investigation its looking actually like a vanos solenoid could be burnt up... i did read upon the article you have shared.. and i will definitely check all the components i can get to easily tonight, and run it for a few to see if they pop again... hopefully thatll do the trick and a dealer visit wont be needed!
