      04-11-2013, 07:08 PM   #1
sistom
sistom's Avatar
61
Drives: '08 135i M-Sport Coupé
Thumbs down Passenger door won't lock/unlock electonically
A few weeks ago my door lock fuse blew. I couldn't unlock the car with the key fob, the door handles, nor the interior lock/unlock button. I replaced the blown 15amp fuse with a 20amp fuse (as I read to do here on the forums).
Today I noticed when I went back to my car that my passenger door wasn't locked. I closed my car back up and pressed the lock button on the key fob. The passenger door lock won't do anything. I can't still unlock it with the door interior door handle (which I couldn't do before when the fuse was blown) but nothing else will move it.
Any ideas?
Thanks.
      04-11-2013, 07:11 PM   #2
You should never replace a fuse with a HIGHER rating fuse. That is a No, NO.
My guess is your passenger door lock servo is bad and drawing too much juice/amps.
      04-11-2013, 07:13 PM   #3
sistom
sistom's Avatar
61
Changing it now. Will report back here.
Thanks.
      04-11-2013, 07:22 PM   #4
Thanks.
Well... I can tell you its gonna BLOW too! lol
You need to find out why its blowing. Time to pull the door panel off...
      04-11-2013, 07:31 PM   #5
sistom
sistom's Avatar
61
That was not any more fun that it was the first time. Changed out the 20amp fuse back to a new 15amp fuse.
Still nothing.
Ideas?
      04-11-2013, 07:32 PM   #6
sistom
sistom's Avatar
61
Ok. Any idea what could be causing it?
      04-12-2013, 07:33 AM   #7
Lester
Drives:
Do you have comfort access?
      04-12-2013, 01:19 PM   #8
sistom
sistom's Avatar
61
No sir.
      04-17-2013, 05:20 PM   #9
sistom
sistom's Avatar
61
so it just started working again on its own...
what the hell?
      04-17-2013, 10:50 PM   #10
Adam135
Drives: 2014 435i
what the hell?
Sounds like the actuator is dying.
      04-17-2013, 11:00 PM   #11
Or the wires inside the door(or A pillar) are broken or shorting out to the body of the car.
