      05-15-2013, 02:09 PM   #1
TT1351
TT1351's Avatar
508
Drives: 135, GTS, E30 M3+
anyone know what code AC69 is?
trying to find out what code AC69 is, used the Bav Tech scanner and found this code, wiper motor blocked, will not send a code. Wipers cycle a few time then stop, changed the relay with an new OEM relay, didn't cure the problem. Scanned the fuse box and found the code there, trying to figure out the problem and the fix, Thanks Fran
Its on an 09 335 X drive coupe, but I suspect all the codes are universal for these generation cars.
