07-09-2013, 04:08 PM | #1 |
Supreme Allied Commander
3843
Rep 54,362
Drives: F80 M3
New Product - Swift Spec-R Sport Springs for your E82 135i
Swift made Sport Springs Spec-R is made for true track racing enthusiasts that wants to take their vehicle to the next level.
Sport Springs Spec-R is engineered with 2 main characteristics. 1 Redesign lowering ride height to maximize the suspension performance allowing the vehicle to fully absorb road condition for maximum traction. 2 Increase in spring rate to further enhance cornering speed through entry & exit. The increase in spring rate is based on the vehicle factory stock valving settings. Sport Springs Spec-R is increase to the optimal rate that the stock shocks can handle. Higher performance shocks are not required, but recommended. Spec R springs are wound with the same engineering as our sports springs. With the exception of stiffer rates and slight change in ride height; you can expect the same characteristics as our sports springs. H5S.TW Motorsport's most advanced spring material Swift made a name for itself on the tracks of Asia, Europe, and U.S. by defying all accepted concepts and speculations about the future, if any, in coil spring science. When many other company were looking at expensive and brittle titanium composites to create the next evolution of springs, Swift was looking at reinventing the entire science of coil spring dynamics. Swift saw that most others are using the old regular silicone chrome material, which was not strong enough. It used a heat tempering method that damaged the strength of the material that requiring more coils, in turn, more weight. The material was also suffering from a short life span. With springs like this leading the industries, Swift saw room for improvement. Swift's R & D team created material, called H5S.TW, which is stronger then regular silicone chrome material. Because of this material, we could make the spring wire thinner, and could wind the springs with fewer coils, which greatly decreased weight while dramatically increasing available stroke. 135i lowering: 1" in the front and 1" in the rear (from non-sport) or 0.5" front and 0.5" rear (from sport) Spring rate: -3.6kg/mm or 201 lb/in in the front -9kg/mm or 503 lb/in the rear ***Available on 7/15*** Last edited by HP Autosport; 10-23-2013 at 04:06 PM.. |
07-09-2013, 06:04 PM | #2 |
695
Rep 3,267
Drives: 2010 128i
Are these sort of a "consumer grade" version of Swift's metric springs?
____________________________ |
07-09-2013, 07:01 PM | #3 |
Rep 4,040
Drives: 130i coupé ;)
These are very interesting, I have been considering them for a month or two.
offer same height as eibach pro, and rates tuned on a 135i with perf shocks/suspension ( i emailed them)
07-09-2013, 08:05 PM | #4 |
1Addict
3233
Rep 7,894
So these were developed for use with the BMWP dampers and NOT the M Sport dampers? Unfortunate if true.
07-09-2013, 08:58 PM | #5 |
Just one more taste...
566
Rep 2,011
07-09-2013, 09:57 PM | #7 | |
Rep 4,040
They said other dampers are compatible too. I think a KONI would be a nice shock to pair with
07-09-2013, 10:45 PM | #8 |
3843
Rep 54,362
Drives: F80 M3
These Spec R springs were developed around the stock M-sport dampers and is compatible with other after dampers such as Koni Yellow.
07-09-2013, 11:08 PM | #9 |
Rep 4,040
^^ Thank you. I guess I didn't understand their email reply, didnt mean to confuse people. Their Perf suspention implied m-sport
07-09-2013, 11:13 PM | #10 |
695
Rep 3,267
Drives: 2010 128i
If these are a one-size-fits-all type of lowering spring, like Eibach's or H&R's, I would expect them to be compatible with a pretty wide range of dampers. In any case, I doubt there's enough of a difference between the M-Sport and BMW Performance dampers anyway (at least not enough to make a difference in this context).
07-10-2013, 12:57 AM | #11 |
Rep 2,643
Its just my opinion, but I think it would be crazy to keep stock 1 series M-sport dampers with upgraded springs.
I can say from my own experience the Performance dampers are a lot firmer than the stock ones. Still, the adjustability of Koni yellows seems very attractive for these. |
07-10-2013, 07:08 AM | #12 | |
566
Rep 2,011
My Build Thread: Jet Black 6MT 128i with MSport
07-10-2013, 11:06 AM | #13 |
1Addict
3233
Rep 7,894
Thanks for the answer! Looking forward to reviews on these.
07-10-2013, 11:53 AM | #14 |
3843
Rep 54,362
Drives: F80 M3
We are looking for a couple of interested parties looking to install these Swift Spec R springs on their 135i. Springs will be at cost plus shipping to you. Please PM and include a few product review threads for reference.
07-10-2013, 12:31 PM | #15 |
1Addict
3233
Rep 7,894
I might be interested, please PM me details!
07-10-2013, 01:41 PM | #16 |
Rep 2,347
Son of a biscuit!
I just got a set of BMWs Performance springs, how much better our these? I may just get them to have a full inch drop on my car instead of the half inch drop from the performance springs. Any info will be helpful, ill test these out and write a review!
Mods:-Berkexhaust -alpinaB3flash -CobbAP -Cobb FMIC -ER charge pipe tialQ bov -M3 front sway bar -M3 subframe bushings -M3 front upper and lower control arms -M3 guide rods -M3 rear upper control arms -Mfactory LSD -defiv lockdown kit -TC Kline SA coilovers /camber plates- HP rear toe arms |
07-10-2013, 07:06 PM | #17 |
Rep 2,643
If the average user thinks the stock M-sport suspension has sufficient damping from the factory, then it says they are either ignorant or value ride quality in preference to handling. I simply can't see how increasing the spring rates by 66% over M-sport stock is going to allow the M-sport dampers maintain any damping control at all.
07-10-2013, 07:33 PM | #18 |
Rep 257
I'm in the same boat. Just installed the BMW performance springs with Koni Yellows in the Spring. If there is a significant performance increase over the BMW Performance Springs I would be interested. Although the spring rates look very similar to those of the performance springs. I wish they would have been a bit stiffer.
07-12-2013, 07:40 AM | #19 | |
Rep 2,347
07-12-2013, 07:44 AM | #20 |
Rep 6,196
These look very promising. Was thinking of the H&R OE Sport for a mild drop (1" and 1") without the rake. Looks like these are hopefully a better choice for handling, a little stiffer than the OE Sport with the same drop.
Anybody know the spring rates of the H&R OE Sport in comparison? Are the rears linear rate or variable? |
07-12-2013, 07:59 AM | #21 | |
Rep 257
Here is a pic with my stock 18s Here is another pic with my 17" track wheels |
07-12-2013, 09:33 AM | #22 |
Rep 2,347
Thanks for the quick response
Very clean car man
