11-13-2009, 02:18 PM | #1 |
Change for a Nickle?
14
Rep 875
The Winter Project
2002 WRX Rally build!
My friend's son blew up the motor in his WRX. It turned out to be cheaper to buy a wrecked complete car at auction and take the motor out of it than to buy a motor with around 70,000 miles on it. I ended up picking up a 2004 WRX motor with a spun bearing on ebay about a month ago for $250. So, the motor's getting rebuilt and so is the car... to rally. Here's the car. There's no damage on the other side of the car. And, as incomplete as it looks, we have all the parts, except for the hood and fender. Now we just have to get it moved to my house.
"I tasted death many times on the river today. Do you want to know what it tasted like? Do you REALLY want to know? Well I'll tell you then: it tasted like BEEF JERKY." - unknown paddler 8/1/09
11-13-2009, 02:43 PM | #2 |
Dangerous Curves
96
Rep 1,148
Drives: better than the boys ;)
I dig the white. Are you really gonna Rally it?
11-13-2009, 02:47 PM | #3 |
14
Rep 875
The first season will probably just be rallycross. After that, yes.
11-14-2009, 08:12 AM | #5 |
Rep 2,474
well i think your insane, but try not to blow this motor up too.
AW 135i w/ blackette, performance short shift kit, BMW alarm, Performance rotors, APEX ARC-8 wheels, Direzza Star Spec 235/275, Dinan stage 3 suspension, M3 wishbones/tension rods/front sway/rear subframe bushings and thats all folks! |
11-14-2009, 09:40 AM | #6 |
14
Rep 875
Welcome to my world... What? It actually took you this long to figure that out?
I didn't blow up the last one but I'll try not to blow this one up.
11-14-2009, 09:42 AM | #7 |
14
Rep 875
Oh yeah baby! I also hear that an extra coat of wax will take 10 seconds off your stage times.
11-14-2009, 01:39 PM | #8 |
winter mode
62
Rep 2,057
Drives: 08 135i, 88 M3
mike you bamf...way to be. can't wait to see how this thing turns out. how long do you think it's gonna take?
88 M3: BMWCCA J Sport
08 135: because streetcar |
11-14-2009, 03:46 PM | #9 |
14
Rep 875
Not entirely certain. April or May is the goal. Money will be the biggest deterrent.
11-14-2009, 03:50 PM | #10 |
14
Rep 875
The first step in the project is done... build a workbench.
11-15-2009, 11:30 AM | #11 |
Rep 2,474
Nice bench! save a weekend in march for my car!
11-16-2009, 09:20 AM | #13 |
Mr. Nice Says Hello
635
Rep 16,662
Drives: BMW M3 | X5 xdrive 35i MSport
very nice.. subscribed to see progression
11-16-2009, 09:28 AM | #14 |
14
Rep 875
Here's two to choose from. Does either resolve the tire issue?
11-16-2009, 10:10 PM | #15 |
14
Rep 875
Disassemble the front subframe so the crossmember can be cleaned up and powdercoated
11-16-2009, 10:15 PM | #16 |
14
Rep 875
and new parts, like these along with a STi steering rack and replacement right front steering knuckle and subframe, can start going back together.
11-16-2009, 10:23 PM | #17 |
Rep 1,262
Have you considered running the RPM (or other similar) subframe(s)? You can save nearly 40 lbs and get a more rigid design.
FYI: those steering rack bushings make a HUGE difference. '04 STi rack, right?
11-16-2009, 10:29 PM | #18 |
14
Rep 875
Correct, 04 ST rack. For the time being, we're just going to run the stock subframe because I was able for pick one up for just a little over $100. We are going to be running GTSpec frame bracing, which the other guy working on the car with me can get at cost from a local parts shop. So it has been considered but will end up being a future upgrade.
11-16-2009, 10:41 PM | #19 | |
Rep 1,262
Have you looked in to picking up an X-brace for the rear, at all? They're a bit pricey, but make a HUGE difference. Based on the looks of things, you probably even have the means to fab your own up (assuming you're not simply planning to run a full cage, in which case it's not really necessary). Lastly, did you stick with the EJ20 mostly because of how cheap you picked it up (vs. running an EJ25) or are you also sticking to a 2.0L due to some sort of rally regulation. By the way, I'm just curious. I'm HUGE Subie fan here... Previous car was a big turbo STi with ton o' mods. Here's a pic in the glory days: (Click for a larger image) And here's a pic from one of the meets. I still run it bi-weekly, regardless of picking up my 1er.
11-16-2009, 11:23 PM | #20 |
14
Rep 875
We stuck with the EJ20 because it matches the ecu in the 02 WRX body and the motor was picked up for $250. The initial intent is to keep the car road legal and maintaining the stock ECU that matches the VIN on the body will help. Because the car currently has a salvage title, it has to be inspected by the state police to ensure that it wasn't stolen or been through a chop shop before it goes for the safety and emissions inspection. Assuming that the all of the receipts are kept, it can be demonstrated that the structural body work was done and the stock restraints are not removed (airbags and seat belts), it should go relatively smoothly.
We are building the car to the NASA Rally Sport rule book and making sure that the Rally America specs are also met (or can be relatively easily where difference exist). So, it will be getting a full cage. The other guy on the project has a friend that is going to do the cage for us. I also had an 04 STi. I really liked the car but got very tired of living with it. It had an APS intake and and turbo back exhaust, dyno-tune and some basic suspension mods. The exhaust was guaranteed to get me pulled over about once every six weeks, although I never actually got a ticket. It was really starting to verge on harassment. As a daily driver, I'll take my M any day over the STi.
11-17-2009, 09:23 PM | #21 |
14
Rep 875
We learned today that the bearing on the #4 cylinder connecting rod spun in the $250 motor, which is exactly what I was told. The crank is pretty badly scored, so its good that the crank that came out of the blown motor is still good. We also learned that the compression in all cylinders is very low at less than 20 psi. This was by hand turning the motor. I was expecting low numbers, but not that low. Time to spit the cases. :-(
The reason for the spun bearing: an improperly torqued connecting rod bolt
11-18-2009, 05:00 AM | #22 |
Rep 2,474
wow you guys are moving quickly
