03-22-2015, 09:13 PM | #1 |
Rep 325
128i wheels on a 135i
I give up guys...
Either I buy some non run flats for my car or I get some used 128i rims with some tires... The pot holes and overall road conditions are leaving me with a migraine... Help!
Mods: Clutch stop, BMW performance SSK, BMW PE exhaust, CDV delete, Clutch pedal spring delete (CPS delete) : ) - check out the the DIY:http://www.1addicts.com/forums/showthread.php?t=1122797
03-22-2015, 11:20 PM | #2 |
Rep 272
Drives: 2008 128i
I run my 17" stock 128i wheels with my winters and a meaty sidewall. I have the BMW Performance calipers on the front so the 17" will fit the 135i no problem, since its the same caliper as your stock. I also raise the front about 2" and soften the Koni's in the winter just to better deal with the potholes and snow. May be an option for you next winter. As for me, can't wait to get my summer wheels and tires back on, and get my stance back.
Afe Scoops and CAI, PBX, BMS Paddleshift upgrade, 261M's Powder Coated Gunmetal, 225/255 Michelin PSS, (BMW Performance: BBK, Illuminated Door Sills, Shifter Knob and Boot, E-Brake Handle, Steering Wheel, Front Strut Bar), E93 FSB, E92 RSB, M3 Rear Subframe Bushings, M3 Front Control Arms, HPA coilover kit (Koni Adjustables and Swift Springs), Steel Brake Hoses, Black Kidneys, Smoked LED side markers, Blacklines, Msport lip spoiler...
03-23-2015, 04:27 AM | #3 |
Rep 8,165
I run M207's in OEM staggered size as winters on my 135i with no problems. It's a tight fit, though, can't put little wheel woolie between the caliper and the rim when washing.
03-23-2015, 06:26 AM | #4 |
Chief Warrant Officer
1025
Rep 1,638
I run BMW 17" 141 style in the winter with higher sidewall rfts (50 front and 45 rear, iirc) and it's not bad on crappy New England roads.
I'm not sure what model 141s originally came on though. In my case, the dealer had them sitting around collecting dust already wrapped in good snow rubber (someone ordered then didn't take delivery). I got them for a steal, especially coming from a stealership. Only problem is that I don't love the looks of the 141. I don't hate them, but I certainly don't love them.
"Prius" is Latin for Eunuch.
"Hrothgar": 2012 135i: 6MT M-Sport, BSM/Blk; Nav, Premium, Convenience, HK Dinan Stage 2 +PPK /// BMW PE /// VRSF CP /// K&N /// Koni Sports /// RSFB Inserts /// MPS4S 225/255 /// Other Stuff |
