      08-19-2023, 08:44 PM   #1
carcar123454321
Drives: 135i, Solstice GXP, Subaru Leg
Will thicker bar aftermarket front kidney grill hurt cooling?
So, I'm probably being over-analytical, but saw some aftermarket front kidney grills and really like the all black and in this case, thicker 2 bar design (more modern). the only worry I have is they seem to block a lot more than the thin "blades" on the stock grills and cooling is one thing these cars don't need "less" of. Thoughts?
      08-20-2023, 08:25 AM   #2
blue135
Drives: 2008 135i Convertible
I made the switch to the "more modern" design some time ago on my 135i. Since then I have not notices any real difference in water temperature (I monitor through OBD). Traffic and throttle use seem to have greater impacts.
      09-08-2023, 12:55 PM   #3
an3ony
an3ony's Avatar
Drives: 2011 135i
had them on my 135i and no difference whatsoever. top tip though; when I installed mine, I had to actually heat the plastic tabs on the new grilles and bend them "outward" a bit for them to seat properly.
