05-18-2020, 02:11 PM | #1 |
Rep 128
'12 128i with 119k w/SULEV broke down.
Brought it to my local mechanic. Apparently it's the fuel control unit. It will run for about 10 minutes before failing after which it needs to wait about 30 before restart.
No symptoms before shutting down though. So I'm having it towed to my local BMW place. $159 diagnostic. Hopefully the SULEV warranty covers this. Anyone encounter this issue before?
"Rear Wheel Drive, the way God intended. If a car is being pulled from the front, doesn't that mean it's being towed?"
05-19-2020, 10:23 AM | #2 | |
Rep 28
05-20-2020, 11:20 AM | #3 |
Rep 128
Needs fuel pump
Fuel pump control unit. Coding for new pump. ECU updates. Valve cover. $3851.50 total. All covered under SULEV warranty. They're also doing an oil change and brake fluid change. Go me.
Suprgnat2330.50 |
05-22-2020, 10:47 PM | #5 |
701
Rep 3,268
Drives: 2010 128i
WTF, how was that so expensive? Your final bill was more than 10x the cost of a brand new Genuine BMW EKPS module! And why did they go anywhere near the valve cover?
____________________________ |
05-28-2020, 11:26 PM | #6 | |
Rep 128
The valve cover alone was just shy of $1800. The pump was $935, the control unit was $707. Plus programming for another $263. My total out of pocket was $310 for an oil change and brake fluid change.
05-29-2020, 09:51 AM | #7 |
Rep 2,276
Lucky you. If you have the desire, the place, and intend on keeping the car for a while, try and learn to do oil change and brake flush yourself. Many of us can do those 2 things for well under $100.
06-01-2020, 11:27 AM | #8 | |
Rep 506
06-02-2020, 02:09 PM | #9 | |
Rep 128
I still have that car. Just getting it ready for sale.
06-02-2020, 02:10 PM | #10 | |
Rep 128
Either way, BMW offered it installed for free, who was I to refuse?
09-18-2020, 10:06 PM | #12 | |
Rep 58
03-03-2021, 09:57 AM | #13 |
Rep 128
None. No drivability issues, no warning lamp, nothing.
03-07-2021, 03:49 PM | #14 |
Rep 101
People need to not let the gas run down so low. Should fill up tanks more often when it is at least half a tank one should try to fill up. Also, use a top tier gasoline with a lot of detergents.
