08-27-2023, 02:52 PM | #1 |
Rep 219
Suspension recommendations for mild track build- SCCA TT Sport 5
I'm thinking about building my E82 128i for SCCA Time Trails Sport 5. It's a very restrictive ruleset. I had a few questions:
1. Sway bars are limited to essentially whatever you can find at Tirerack (Eibach, H&R, etc) or factory options. What sway bars would you recommend? For reference, the car will NOT be allowed to run a LSD, so I'm hesitant to run too much rear bar. 2. The springs and shocks are also very limited, mostly to what is available at TR, with a few exceptions. I was planning on running Koni yellows with a set of Swift R springs (for a 135i, which I'm assuming should be just fine?) unless anyone has any alternate recommendations? 3. Camber plates are allowed on MacPherson strut cars, but have to be used in conjunction with commonly found springs/shocks (NO threaded coilovers). What camber plates would you folks recommend? I would like to try and shoot for -3 camber if possible, to help with grip as well as to help fit the class limit width for 200tw tires (245 wide). Thanks in advance!
2008 Honda S2000 (weekend/former autoX) - 1996 Acura Integra GS-R (occasional autoX) - 2008 BMW 128i 6MT (track/time attack) - 2008 Nissan Xterra (winter beater)
08-28-2023, 04:44 PM | #2 |
Supreme Allied Commander
3867
Rep 54,426
Drives: F80 M3
You can experiment with from bar size depending on your particular setup. E90/92 bar is slightly larger than the E82. The E93 bar is the largest of the OEM bars. You are on the right track for no rear bar. You might even find it helpful on an autocross course with it remove altogether.
Koni Yellow is likely the best damper with rebound adjustment. Swift is no longer making the Spec-R spring for the 135i, so you are left to find them on the used market. We like Vorshlag plates with OEM top hats. -3 is possible on a lowered vehicle. PM us if you have any other questions regarding setup or parts. |
tracer bullet2457.50 |
09-01-2023, 04:40 PM | #3 | |
Rep 219
After further research, I don't believe the 128i will be terribly competitive in SCCA Sport 6, so I'm either going to shoot to build it for SCCA Tuner 4 or NASA TT5 (more likely). Thanks for taking the time either way, though!
09-01-2023, 05:47 PM | #4 |
Rep 467
Drives: 11 128i 6MT Sport
Yeah, I was trying to come up with a response to your original question but I just kept thinking how frustrating that ruleset would be for the 128, glad you came to that realization as well!
11 128i slicktop
13 WK2 19 Alltrack S |
09-05-2023, 01:56 PM | #5 | |
3867
Rep 54,426
Drives: F80 M3
12-10-2023, 08:29 PM | #6 | |
Rep 58
OBD-based ECU reflashesKoni Yellows, plus Swift R springs (can find them used), front and rear sway bars, a tune and camber plates get you a pretty solid track car. Throw on some 17x8.5s with 245/40R17 RE71RS, and it's going to move. You have to deal with NDs and first-gen Twins, but the 128i is going to have better gearing and should be faster on any tracks with long straights. It's not going to be a walk in the park, but it's not an underdog, either. |
