12-15-2016, 02:45 PM | #1 |
Rep 338
Drives: 2013 BMW 135is
Cornering Light Malfunction - What bulb to replace and get?
Hi, I'm a new owner and I've found other threads about this but little with what people actually replaced and what bulb they used. I've got a 135is. I've heard I probably need to get a new bulb to remove this error for good. It's intermittent right now and goes away rather quickly. (Left cornering light malfunction) But I'd rather just solve the problem forever. Which bulb do you suggest to get rid of this and which one would I be replacing? I was on RockAuto and saw too many options for me to make a simple purchase. I really want all the lights to look and project stock/OEM light.
Thanks in advance. EDIT: Read the whole thread. Turns out there was a mistake along the way. I have since made a video demonstrating a method to replacing the bulb. This is how it worked for me. YMMV Last edited by TridenTBoy; 01-15-2018 at 10:29 PM.. |
12-15-2016, 02:56 PM | #2 |
Rep 6,196
The cornering lights don't really do much. They are the inner lights in the headlight, the ones that look like they could be a high beam. They only come on briefly when you put your signal on, or when you "flash" the highbeams, which does not actually activate the high beams.
Dackelone10538.50 |
12-15-2016, 03:02 PM | #3 | |
Rep 338
I don't mind if they don't do much... I just want the error gone *forever*. |
12-15-2016, 03:29 PM | #4 | |
Rep 6,196
It is a standard H8, 35W bulb, #1 as seen on realoem. http://www.realoem.com/bmw/enUS/show...diagId=63_1006 |
12-15-2016, 04:26 PM | #5 | |
Rep 338
Looks like PHILIPS 12360 is the OEM bulb. |
12-15-2016, 10:54 PM | #6 |
Rep 524
I've had this error a bunch, on both sides. If you have iDrive, click into the error dialogue and make sure it's actually the left. My top banner error always says left, but when actually looking at the detailed error message in iDrive it has specified the right one.
The service log was a bit unclear which bubs were replaced in each case, but I think it was either the headlight turn signal or the door turn signal in at least one case. My error popped up the same way yours does, right at start-up and then goes away quickly. In all cases it was actually a burnt out bulb, or at least on the verge of burning out. I was never able to figure out which bulb was dying because they all seemed to be working when tested.
'13 128i | 6MT | SGM | Black Boston | Black Gloss | Lighting | Premium | Tech | HK | Anti-Theft | [CDV-Delete | Clutch Stop | 30% Pinnacle]
Ordered 2.23 | Production Begin 3.7 | Ends 3.15 | Released to carrier 3.18 | At port 3.19 | Departed 3.23 (K-line to Brunswick) | Arrived 4.7 | Truck 4.12 | Dealer 4.19 |
12-16-2016, 05:07 AM | #7 | ||
Rep 22,992
CCID error codes...
http://www.endtuning.com/ccidcodes/ Quote:
Mach1er88.00 |
12-16-2016, 03:20 PM | #8 | |
Rep 338
12-16-2016, 03:53 PM | #9 |
Rep 524
12-16-2016, 05:14 PM | #10 | |
Rep 338
12-18-2016, 11:35 PM | #11 |
Rep 338
Replaced the front right light bulb. Error is still coming up here and there. Same behavior as before. Sometimes it goes away, sometimes it doesn't. I could try replacing the front left but at this point I feel like I'm throwing money down the drain.
12-21-2016, 03:49 PM | #12 |
Rep 338
Been looking around but don't see anything:
How do you replace the left/drivers side light? The cover is blocked by too many things to just pull it out. I barely managed to get the passenger side. The drivers side is fully blocked. I can imagine the only way to really replace the bulbs is by removing the entire headlamp assembly out of the car. :/ One reason mine is more difficult is that I have a convertible and I think all the videos out there are on coupes. From what I am seeing, there are metal bars in the way of the headlamp covers and I figure these are part of the chassis strengthening. Either that or part of the 135is... Either way, hard knock life. Last edited by TridenTBoy; 12-21-2016 at 04:05 PM.. |
04-29-2017, 05:16 PM | #13 |
Rep 338
Finally replaced the drivers side. Had to remove the bumper and the headlight assembly to change it.
Guess what? Error is still coming up. F'ing BMW. |
04-29-2017, 05:21 PM | #14 | ||
Rep 22,992
What did the CCID codes reveal ? Quote:
When the headlights are on, the xenons are on. The highbeam function works via a electronic shutter inside the headlight box/lens. Dack
04-29-2017, 05:27 PM | #15 | |
Rep 338
At this point, I want to code out the voltage monitoring but I don't know if I even can because I have a 2013. (Something about encryption or what not?) |
Dackelone10538.50 |
04-30-2017, 10:06 AM | #16 |
Rep 3,544
I'd contact the Carly site via email, it can take a few days to get an answer but you very likely will get one. Let them know the details of your car, and the current flash on it from BMW if possible, and see what they have to say.
You might be able to run a trial of the app??? |
05-26-2017, 02:45 PM | #17 |
Rep 644
I just got a 2012 135 and had this same issue, kept getting the CC error but the lights worked most of the time. I took it apart and there was significant corrosion on the bulb carrier, I cleaned it up with some sand paper and it's all good now. I put in new bulbs while I was in there too.
Just an FYI for anyone else, you don't need to take off the bumper and head light, you just have to remove the weatherstrip and the "rail" piece. There's a good DIY on here: http://www.1addicts.com/forums/showthread.php?t=239169 |
05-26-2017, 02:57 PM | #18 | |
Rep 338
Ugh. I replaced #1 in this image: http://www.realoem.com/bmw/enUS/show...diagId=63_1006 Should I have replaced #12? |
05-26-2017, 03:19 PM | #19 | |
Rep 6,196
When you are actually looking at the headlight, they are opposite of that. The "halo" light is more towards the middle. |
05-26-2017, 03:30 PM | #20 | |
Rep 338
Wasted a bunch of time and $20+ on the wrong lights. Sigh! Well, at least, they're new... but now I'm looking at getting the LUX H8 V5 adjustable anyway because I don't like the orange halo. It makes the car look so dated. Now I know how to replace them at least... |
05-26-2017, 03:31 PM | #21 | |
Rep 6,196
05-27-2017, 12:46 AM | #22 |
Rep 338
Went to auto parts store. Bought a sylvania basic h3 bulb for $6 and replaced the left. Didn't solve the problem. Took the old left and put it in the right. That seemed to solve it so far. Tomorrow will tell...
Pro-tip: be careful with that weather stripping holding plastic and the strip itself. They're both very fragile and break and tear easily. Some of the plastic clips the plastic thing slides over broke when reattaching. All well, I can just baking soda and Super glue them back to working position. Had to do that for other plastic bits here... |
