08-27-2009, 08:12 AM | #1 |
Rep 4,528
Drives: M2 CS
Adding an Amp and Subwoofer
Hey guys!
I'm in the middle of parting out my G35. I have a JL 500/1 amp and a JL 10w6, I really love this set up and dont want to sell it What will I need to do to make this work w/ the stock headunit? would I just need a LOC? The 135i I'm ordering will have HiFi system, iPod and smart phone integration I've done lots of research but can only find people switching the stock Subwoofers Should I just sell it and swap out the OEM Subwoofer for SWS 8xi? Thanks |
08-27-2009, 09:31 AM | #2 |
Got Boost?
52
Rep 601
It's pretty much the same setup as everyone has been doing. The benefit to the SWS is the incognito style of added bass.
You'll just need a signal processor like the PDX-5, or JL Cleansweep |
08-27-2009, 10:09 AM | #3 |
Rep 129
he said he has hifi, not top hifi. so i believe that means no signal processor like cleansweep will be needed.
PDX-5 is an amp isn't it? not a signal processor, though it does have built in crossover. |
08-27-2009, 11:23 AM | #4 |
Rep 1,925
Drives: 2010 135i,1989 PRO3,2001 530i
I figured you would need the LC6i to keep the head unit and use your amp, at least that is what i have picked up from reading. I have heard switching out the subs in the car is a great option. I currently have PrecisionPower bridged amp to 2x 12 JL, and PP amp to my Mb quarts up front in my current car...but it eats the trunk space! So i was planning on keeping the stock HU, adding the LC6i and hooking up an amp to the interior 8" subs and MBquarts up front. I just got the std radio.
I am still waiting for my car...so no real input yet
135i coupe 6MT TiAg ///M sport http://www.rhominnovations.com www.musicarNW.com www.unitedBMWonline.com |
08-27-2009, 11:43 AM | #5 | |
Rep 4,528
Drives: M2 CS
thanks for all the help so far guys i loe a lil bass, nothing crazy. maybe the stock system will be enough how do you guys like the hifi system? |
08-27-2009, 02:41 PM | #6 |
Rep 1,925
correct, the standard radio is HD in the 2010
Hopefully they also improved the HPFP!!!!
08-27-2009, 07:59 PM | #7 |
Rep 652
Here's a couple pics of my setup. I was in a similar situation as you being that I had a JL 500/1 & W6 10" in my old M3. Didn't want to just sell them for the Earthquake subs (I haven't heard the earthquakes, but I'm sure they're not as good as the JLs), so I ended up with this:
08-27-2009, 10:32 PM | #9 | |
Rep 905
More details please! IS it a DIY or audio shop built? |
08-28-2009, 08:52 AM | #10 | |
Rep 5,970
Very nice. I hadn't thought about how easy the battery location makes adding an amp. No long power leads is great! |
08-28-2009, 10:44 PM | #11 |
Rep 652
I wouldn't say it's a DIY for all unless you've done fiberglass work before. I wish I took pics along the way to show the process. I didn't want to take up all the room in the trunk or add excessive weight by building a full box. I wanted a clean setup so I decided to use my JL W6 10" in the corner and hide the JL 500/1 amp under the cover. Suprisingly the amp fits PERFECTLY. Looks like it was meant to be there. I used a LOC for the amp & ran the remote wire from the fuse box behind the glovebox.
08-31-2009, 01:02 PM | #12 | |
Rep 4,528
Drives: M2 CS
any pics of how the remote is mounted in the glove box? i might be hitting you up w/ some questions in the near future thanks again |
08-31-2009, 01:17 PM | #13 | |
Rep 1,262
The only thing I wish I had is an enclosure like the one you have. The current, ported enclosure takes up A LOT of room. Did you build this or have it done? If it's your own build, do you think you could do another for a reasonable price?
08-31-2009, 02:24 PM | #14 |
Rep 13,011
There is a remote line at pin 10 (thin black wire) in the OEM HiFi (non-Logic7) amp connector in the trunk. The remote wire in the Logic7 system is located in pin 13 in the back of the OEM HU or iDrive computer.
09-01-2009, 07:03 AM | #15 |
Rep 4,528
Drives: M2 CS
+1 make more of these, you will make a killing!
i would buy one this second! thanks man! |
09-01-2009, 11:35 PM | #16 |
Rep 652
I made the enclosure myself. Never really thought about making more to sell. I do it more as a hobby. I guess it's really the best setup for in trunk since it doesn't take up too much room. I tried to tap the remote wire off the thin black wire off the factory amp, but I guess the JL amp I'm using required a stronger signal so I ended up tapping it from the fusebox behind the glovebox. I don't recall which fuse I ended up using, but I'll check it out tomorrow.
09-02-2009, 07:27 AM | #18 | |
Rep 4,528
Drives: M2 CS
09-04-2009, 07:28 PM | #20 |
Rep 652
What would you guys be willing to pay for an enclosure like that? Like I said before, I do it more as a hobby, but if there's interests & it's worth the time I put into them, I don't mind making more. I probably wouldn't recommend anything bigger than a 10" do to size restrictions on the side. I have a JL W6 12" that I was thinking about using, but it definitely wouldn't have fit right. So.....what would you guys be willing to pay for an enclosure like that? I can either wrap in carpet like mine, or paint if you want a flashy look. Let me know what you guys think!
