      04-21-2020, 06:09 PM   #1
N55135i
N55135i's Avatar
Drives: E82 135i N55 6MT
2011 E82 135i N55  [10.00]
2008 Fiesta  [0.00]
Exclamation Do you know what these are for!!?
In the picture I have removed One of the 'nubs' on the performance brakes for my E82. Do they serve any purpose other than making the caliper look huge & being heavy. I'd like to remove all of them if they are unnecessary, maybe I should ask Brembo. *These calipers will be painted Sedona Red to match my car.
      04-21-2020, 09:25 PM   #2
Suprgnat
Слава Украине!
Suprgnat's Avatar
Ukraine
2317
2013 128i  [9.58]
Originally Posted by AHighSpeedDriver View Post
In the picture I have removed One of the 'nubs' on the performance brakes for my E82. Do they serve any purpose other than making the caliper look huge & being heavy. I'd like to remove all of them if they are unnecessary, maybe I should ask Brembo. *These puke yellow calipers will be painted Sedona Red to match my car.
Vibration/squealing/noise. I removed mine with no ill effects. YMMV
Inertia is the enemy!
N55135i269.00
      04-21-2020, 10:08 PM   #3
asbrr
Drives: 2014 335ix M-Sport
Would they add any heat sink properties? Like adding mass to a rotor, and just help with overall heat management?
      04-22-2020, 02:58 AM   #4
N55135i
N55135i's Avatar
2008 Fiesta  [0.00]
Your comments are much appreciated. I will leave them off, weight savings & better looking caliper shape without them. Awesome photo history Suprgnat
Suprgnat2317.00
      04-22-2020, 08:33 AM   #5
ShocknAwe
1Addict
ShocknAwe's Avatar
3234
Drives: E82 Mutt, M57 Truck
I've had mine off for 5-10k miles or so. No problems.
They're a vibration damper.
2010 135i 6MT Jet Black
N55135i269.00
      04-22-2020, 11:33 AM   #6
Suprgnat
Слава Украине!
Suprgnat's Avatar
Ukraine
2317
2013 128i  [9.58]
Given that they're steel I would imagine they would tend to retain heat more than the aluminum caliper bodies.
      05-18-2020, 06:08 PM   #7
N55135i
N55135i's Avatar
2008 Fiesta  [0.00]
Update: Asked my local German mechanic, he also said vibration/noise. I'll leave em off though & find out myself, theyre easy to re-install.
      09-02-2020, 04:41 AM   #8
breakingpoint
Drives: E92 330i
I was wondering the same thing. I saw a picture of an E46 M3 with the M performance brakes, without this bracket. It looked so good! So I came to the 1-series forum to investigate, as they're standard on the 135i. I did not like the look of the performance brakes with this nub. Would be great to see more pictures of setups like this!
E92 330i N52K 200kW (EU)
N55135i269.00
      09-02-2020, 05:23 AM   #9
N55135i
N55135i's Avatar
2008 Fiesta  [0.00]
Here's an image of my Brembo install without the nubs. I have a few thousand miles on them now & I have not had any issues. My car is not a 135i so I can't use them to their full potential (weaker booster*). This is also why my brake pedal will always be softer too despite steel flex lines. Breaking from 200kph+ is however much more stable & shorter now on Autobahn.
houtan707.00
      09-03-2020, 04:00 AM   #10
breakingpoint
Drives: E92 330i
Looking good, nice idea to paint them the same color as the car!
N55135i269.00
      09-03-2020, 08:11 PM   #11
TM9030
Drives: N/A
Interesting - they look so much better without that piece. Do you have any close up pictures of the caliper
N55135i269.00
      09-04-2020, 03:38 PM   #12
N55135i
N55135i's Avatar
2008 Fiesta  [0.00]
Closeup
Esteban43818.50
TM9030122.50
      09-04-2020, 04:33 PM   #13
Esteban
Esteban's Avatar
Drives: a slow car fast
Closeup
Nice pics with the matching calipers.
Pics also show off the orange in your Sedona Red.
Looking good.
      09-04-2020, 08:35 PM   #14
TM9030
Drives: N/A
Just to clarify - the nubs haven't made the car feel different? Have you experienced higher noise levels or vibrations coming from your front brakes?
I'm really tempted to take mine off. Come to think of it I haven't seen those nubs on other brembos used by other manufactures. Is there a reason why?
      09-04-2020, 10:53 PM   #15
ShocknAwe
1Addict
ShocknAwe's Avatar
3234
No problems but I'm also using different rotors and caliper brackets.
      09-06-2020, 09:02 AM   #16
MightyMouseTech
MightyMouseTech's Avatar
4338
Here's an image of my Brembo install without the nubs. I have a few thousand miles on them now & I have not had any issues. My car is not a 135i so I can't use them to their full potential because I don't have the extra brake lines to use all pistons as I understand it. This is also why my brake pedal will always be softer too despite steel flex lines. Breaking from 200kph+ is however much more stable & shorter now on Autobahn.
Extra brake lines? Uhhh, what?
      02-26-2024, 11:59 AM   #17
N55135i
N55135i's Avatar
2008 Fiesta  [0.00]
Update on nubby removal, still zero problems.
I did the same modification to my 135i's Brembos.
brakes, brembo, e82, performance, question
