10-31-2013, 04:54 PM | #1 |
Turbo Power
50
Rep 364
Amount of fluids?
I want to change my transmission and differential fluids. How much quantity do I need for each of these? (Like 1 or 2 Liters?) Please help - Thanks!
BSM 135i - CDV Delete | Bilstein | Eibach | M3 FSB | Whiteline
10-31-2013, 04:56 PM | #2 |
Rep 22,992
N54 or N55 ?
6MT or Auto or DCT ?
10-31-2013, 05:08 PM | #4 |
Rep 22,992
Engine holds 6.5 liters or 6.9 quarts of oil when changing the oil filter. BMW specs: any motor oil that has a LL-1 (Long Life 1) rating on it. 0w30, 0w40, 5w30, 5w40 motor oil.
Manual trans holds 2.1 liters of trans oil. You basically just keep adding fluid until it starts to spill out of the "fill hole" on the side of the trans. BMW specs: MTF-LT-3 Rear diff holds 1.2 liters of fluid. BMW specs: Castrol SAF-XJ For the manual trans I use Redline ATF-D4 and for the trans I use Castrol SAF-XJ. Here are some links that might be of interest to you... DIY: manual transmission and diff fluid change http://www.1addicts.com/forums/showthread.php?t=409293 CORRECT 1M Fluids List [Engine, Transmission, Differential] http://www.1addicts.com/forums/showthread.php?t=620282
10-31-2013, 07:01 PM | #5 |
Rep 131
I would suggest Redline MTL 75W80....been using it for 5 years now, both on my e82 as well as e36 M3....good quality stuff. (Use it both in diff and manual trany)
10-31-2013, 07:49 PM | #6 | |
Turbo Power
50
Rep 364
http://www.redlineoil.com/product.aspx?pid=133&pcid=4 And yea I want to use the D4-ATF for the transmission.
10-31-2013, 07:53 PM | #7 |
Turbo Power
50
Rep 364
And I thought Castrol SAF-XJ was for M car differentials because they have an LSD.
10-31-2013, 08:31 PM | #8 |
Turbo Power
50
Rep 364
You think I would be fine using that in the diff as well? Because everyone seems to run the 75W90 or 75W140 GL-5 gear oil?
11-01-2013, 04:45 PM | #9 | |
Rep 22,992
^^I think RedLine's 75W90 GL-5 Gear Oil - is a good oil for the diff. But I am using Castrol SAF-XJ at the moment. What did RedLine say? I am using this RedLine 75W90 GL-5 Gear Oil in my "other" BMW. In my old e39 535i V8. I have put almost 100K kms on the car using this RL diff oil(of course I have changed it a few times every 40K kms or so). Dack
11-01-2013, 04:50 PM | #10 | |
Rep 22,992
There is another Castrol gear oil that can be used in our cars(non M models), I think it is SAF-XO (?) but I am not 100% on this. I know there is another oil. But frankly the Redline oils are very good oils - and I would loose no sleep running any of them in my car.
11-01-2013, 08:14 PM | #11 |
Rep 131
11-01-2013, 08:55 PM | #12 |
Turbo Power
50
Rep 364
Thanks man. I think I am going with MTL 75w80 for the trans and 75w140 for the diff as it's similar to the Castrol SAF-XJ.
11-01-2013, 09:06 PM | #13 | |
Turbo Power
50
Rep 364
One final question. I don't really live in cold weather, would I be better off getting the D4-ATF or MTL 75w80 for the trans? The Redline MTL seems similar in spec to the BMW MTF-LT-3
11-02-2013, 02:13 AM | #14 | |
Rep 22,992
I prefer the D4-ATF over MTL. I have been using the D4 for years in my (various)BMW's so thats why I run it.
11-04-2013, 03:01 AM | #15 | |
Rep 93
Hello, are the engine oil amounts for a n52 or for n55 ? How many liters does a n52 hold with a filter change ? Thank you |
11-04-2013, 04:17 AM | #16 | |
Rep 22,992
Checkout @JimD 's excellent DIY oil change thread... First Oil Change on my 128i Convertible http://www.1addicts.com/forums/showthread.php?t=301440
11-09-2013, 02:21 PM | #17 |
Rep 751
Has anyone used the Mobil1 Synthetic Gear Lubricant LS 75W-140 for the diff? 2 quarts should cover it correct?
I am looking to change all the fluids in my 6MT n54 given I'm around 60k miles and read on some other sites that people like the M1. Given it's available locally and have had great experience with Mobil1 engine oils/filters, I was thinking of giving it a go. Thanks. |
01-05-2024, 01:04 PM | #18 |
Rep 13
Hi guys,
Can anyone let me know the amount of fluids for FULL service (and which) go in a E87 120i LCI N46B20 AT? The only thing I know at the moment is engine oil: CASTROL EDGE 5W30 LONGLIFE (my choice) - 4.25Lts Thank you! |
