      05-11-2022, 04:50 PM   #1
fatarayyy
fatarayyy's Avatar
32
Drives: Smg 135i '10
WTS N54 gs6-53bz 335i Manual Swap Kit out of 08 e92 335i 8 bolt crank
BIMMERPOST / Classifieds
Asking Price:
USD 1,800.00
Item Interest
Located 08901 NJ. Here I have a transmission manual swap kit for e9x and possibly e8x? in good condition. Was pulled out of a 08 335i w bad motor and smashed on the passenger side. The clutch is still OEM. The car was bone stock. Here is the list of things you will get. Also unknown mileage.
• Transmission w slave, fork, pin and bolts
• Flywheel with bolts
• Clutch and pressure plate w bolts
• Pedal assembly w master clutch cylinder including the cables for brake and safety ( check pics )
• Shifter assembly with shifter rod and pins.
• MSD81 ecu (THIS WILL BE EXCLUDED 100$ off)
• Front portion of the driveshaft w hardware ( THIS WILL BE EXCLUDED, Not applicable for 135i)
• Trans mount with good bushings
• Clutch lines from firewall with grommet and clips and all the pins and hardware.
• Reverse light cable down to the pin. I pulled it from the ecu connector,
• Shifter rubber grommet and center console pad.
This kit is complete with almost all of the hardware included and ready to be swapped. Please, what I am kindly asking you is not to bother me with anything lower than my asking price. I spent a long time to make this kit complete. FIRM! Thank you for checking out! To REACH OUT TO me faster, dm me on ig 1cholic!
Prefer local, unless you can arrange freight, I will be happy to put it in a crate and box it up for 50 extra.
      05-13-2022, 09:09 PM   #2
Campose82
Campose82's Avatar
30
Drives: 2008 bmw 135i
Hey there! Im interested in this. Not sure how wed go on shipping tho im in california. Could you get me a quote? Thanks
135i, 335i, 6-speed manual, clutch, manual, rwd, swap
