      11-14-2012, 06:50 PM   #1
spray
Drives: 2008 bmw 135i
"Bucking" when accelerating from a stop
Hey guys!
Just bought my 2008 135I, automatic.
When going from brake immediately to accelerator, the car will sometimes "buck" hard before accelerating. It's happened about 6 times since I bought it a couple days ago.
Is this a normal thing? known issue? Any ideas?
Thanks
      11-14-2012, 07:55 PM   #2
ragingpanda
No its not normal. Are you throwing a check engine light? Try to see if you are throwing any codes.
      11-14-2012, 08:00 PM   #3
spray
No check engine light. It looks like I found the issue.
http://www.1addicts.com/forums/showthread.php?t=317163
      11-15-2012, 10:40 AM   #4
MZWIE
Drives: M2
If you are on a slight incline sometimes the hill holder brake kicks in. Then when accelerating it releases and the car lurches.
I have tested this on hills and flats and indeed it does this.
      11-15-2012, 11:43 PM   #5
Dmacc
Drives: 2011 BMW 1M
+1 same thing happens to me, it's completely normal
thanks to MGallop
      11-20-2012, 05:38 PM   #6
Fed P
I recently got a service manual for the 3 series (since there was no 1 series, but an N54 is still an N54), and it says that this is a known issue which can be fixed with a software update, as it says in the thread spray found. So there's a potential solution for you, if you already have the post-lag software =)
      11-22-2012, 10:05 AM   #7
spray
Thanks, the car feels sort of clunkish and a little sloppy in shifts too.
I don't know if that's how it's supposed to be designed or if there's an issue.
