      06-03-2023, 10:23 AM   #1
paixerino
Drives: E87 123d 2011
Tire pressures
Hey!
So i'm planning on buying new summer tires for my e87 123 2011. I read a lot about people switching from 215/40/18 front and 245/35/18 rear to 225/40/18 front and 255/35/18 rear.
Could someone tell me what would be the recommended pressures for these tires, since on the door it ofcourse says only for the 215 and 245 sizes.
Thanks!
      08-20-2023, 03:06 PM   #2
paixerino
Anyone?
      02-10-2024, 06:36 AM   #3
paixerino
Does 36f/39r sound about right?
      02-10-2024, 07:57 AM   #4
Wazowski
Wazowski's Avatar
Drives: 08 135 6MT vert
2008 E88 135  [10.00]
For what its worth, I run 40psi front and rear.
      02-11-2024, 04:32 AM   #5
paixerino
Interesting, would've expected a little different pressures due to staggered stance. Not noticing any extra wear on the sides or the middle of the tires?
Gonna also give this a try when its time to put the summers back on
      02-11-2024, 07:18 AM   #6
Wazowski
Wazowski's Avatar
It’s my daily driver and I get about 20k+ miles on the rears and 35k+ on the fronts (PS4S). NEVER rebalance and they wear “evenly” (other than the minor camber effect on the inside edge). Stock suspension replaced with Koni Yellows about 40k miles ago.
      02-11-2024, 08:47 AM   #7
BMWCCA1
BMW Owner Since 1971
2257
2013 BMW 128i  [10.00]
Tire pressure on the placard is a starting-point and a cover-your-ass legal document for the vehicle manufacturer. Tire pressure should always be adjusted to taste, just like seat and steering wheel position.
The Basics:
To decrease Oversteer
*Lower front tire pressure
*Raise rear tire pressure
To decrease Understeer
*Raise front tire pressure
*Lower rear tire pressure
      02-11-2024, 09:49 AM   #8
paixerino
Normally i would look at the placard, but since i oversized my tires from 215 front to 225 and rear 245 to 255, they don't have any numbers to go by. So i tried to look for something like a 3 series with similar weight and people with 135i/140i to get a good baseline to what people go for, then just tuning from there.
      02-11-2024, 09:51 AM   #9
paixerino
Gonna definitely give a try on the 40/40, im using the bridgestone truanza 6.
      02-11-2024, 01:30 PM   #10
Goodmanfue
Drives: Bmw 135i
I typically do 36f/38r on the street.
