      01-08-2008, 09:12 AM   #1
360bhp
360bhp's Avatar
Drives: German
brakes rust question
love the new 135im but how do you get rid off the rust around the brakes efficiently ? cheers
      01-08-2008, 09:20 AM   #2
mikeo
Santa Fe Concorso
mikeo's Avatar
Drives: '11 M-sport 328i, '13 X1 28i
You're talking about the non-swept areas, right?
1. remove the rotors and paint those areas with a good high temp paint.
or
2. buy stainless steel rotors.
Santa Fe Concorso - The Southwest's Premier Automotive Gathering.
      01-08-2008, 01:36 PM   #3
Brandon26pdx
Drives: 2011 135i
They make these?:iono:
      01-08-2008, 02:19 PM   #4
BMWeber
Drives: 08 135i
no
      01-08-2008, 02:31 PM   #5
grant
grant's Avatar
Drives: 1973 Porsche 911
Carbon-Ceramic rotors don't rust. If rusting rotors is a problem, then you're not driving your car enough
1973 Porsche Carrera RS 2.7 Carbon Fiber (240hp & 1,890 lbs)
      01-08-2008, 02:41 PM   #6
larryn
I'm thinking the original poster might have meant "brake dust"... Just a thought. :smile:
      01-08-2008, 02:51 PM   #7
TGrits10
Drives: 2015 650i GC
If it's brake dust you're talking about, then you have two options:
1) Develop OCD, clean every nook and cranny with a toothbrush, then don't drive it lest you get it dirty again.
2) Drive the piss out of the car, abuse the brakes, and ignore your friends' jabs about dirty wheels.
*Hint* If you choose #2, you get a high five.
      01-08-2008, 02:58 PM   #8
larryn
Replace the pads to EBC Greens and waxing your wheels does wonders to brake dust. Some people swear by WheelWax brand. I've found that any decent wax works just the same, and makes cleanup very easy.
Stock BMW pads make a lot of dust, because they are designed as fairly high performance stoppers.
      01-08-2008, 03:01 PM   #9
mikeo
Santa Fe Concorso
mikeo's Avatar
Originally Posted by BMWeber View Post
no
What was I thinking! I meant plated rotors (a zinc-like metal, IIRC). There are also two-piece rotors available, for a price, that have aluminum hats.
      01-08-2008, 03:12 PM   #10
Andys120
Drives:
There's another choice. use a good wheel wax that will repel most of the brake dust and make what collects come off with a quick squirt.
      01-08-2008, 05:13 PM   #11
C_Topher
Señor Member
I will say the OEM wheels look pretty easy to clean - no toothbrush required.
      01-08-2008, 06:25 PM   #12
Gary@TireRack
Moderator
Gary@TireRack's Avatar
Drives: Formerly 1995 M3
Power Slot rotors are cadmium coated and resist the rust you speak of very well from personal experience.
      01-08-2008, 06:28 PM   #13
atr_hugo
No longer moderate
atr_hugo's Avatar
Drives: '13 135i
Hiya Gill - welcome to the party!
      01-08-2008, 06:32 PM   #14
Ryephile
Not a Newbie
Drives:
Welcome to 1Addicts. It doesn't matter is you love the 135i or not; all steel brake rotors no matter the brand will rust on non-swept surfaces like the edges and hub areas. Most OEM's, like BMW, zinc or cadmium plate brake rotors to keep them from rusting for a while.
[SIGPIC][/SIGPIC]
      01-08-2008, 06:35 PM   #15
Gary@TireRack
Moderator
Thanks...been lurking for months before joining. What a great site.:roundel:
      01-08-2008, 07:30 PM   #16
slipkmaggot
Drives:
welcome to rehab for 1addicts gill!
:roundel: :roundel: :roundel: :roundel: :roundel: :roundel: :roundel: :roundel: :roundel:
      01-09-2008, 07:12 AM   #17
360bhp
360bhp's Avatar
Drives: German
hi again - actually I travel alot and the car sits around - hence the rust. Will some hard braking clear the rust ? tia
      01-09-2008, 07:30 AM   #18
atr_hugo
No longer moderate
atr_hugo's Avatar
Drives: '13 135i
I have a similar problem, since the Miata sits a lot since I'm working from home - maybe there's an expert around here that can chime in but I would think just the opposite is in order - dragging the brakes a bit at low speed to clean the scale off would be preferred.
      01-09-2008, 07:52 AM   #19
mikeo
Santa Fe Concorso
mikeo's Avatar
OK, I see you're talking about the minor rust on the SWEPT area of the rotor after sitting in a humid climate. Entirely normal and as Hugo says, a little low speed light brake application clears it right off.
      01-09-2008, 07:57 AM   #20
Dave
formerly izzo/comeback
Dave's Avatar
Drives: 2016 RC 350 F Sport
2008 135i  [6.80]
bed your brakes properly before the rain...dont power wash them they need the residue on them to brake
but keeping out of the rain always helps and i even know some guys who put fans by all 4 wheels and it keeps it nice and dry and clean
BMW CCA # 418268
      01-09-2008, 09:17 AM   #21
larryn
Since we are talking ab out rust... I have a friend that lives in NYC and only puts a few hundred miles on his car a year. He had rust issues on the discs, and his warranty repair claim was denied due to neglect.
So get out there and drive your cars!!!
      01-09-2008, 09:26 AM   #22
Dave
Dave's Avatar
2008 135i  [6.80]
welcome to the site!
long time tire rack consumer...you friends with luke at tire rack?
plz keep us updated when tire rack gets there 1 because you always get cars earlier than us.
whats ur ext?
BMW CCA # 418268
