      10-04-2022, 03:17 PM   #1
Gustav_555
Smile 2008 135i, 6 speed, m-sport
BIMMERPOST / Classifieds
Asking Price:
USD 18,500.00
Or Best Offer
Item Interest
2008 135i, 6speed, N54, m-sport, in Sparkling Graphite Metallic (Only available on 2008 1er's I believe), mileage is 121,XXX but will go up slowly.
The vehicle has always been garage kept, and is in very good condition, especially for being in the Northeast! It's rarely seen rain or snow, as I usually take the Subaru in bad weather . The engine is completely stock and never been tuned! I had planned on tracking it for the first time next year, but now with a kid on the way, my wife says those plans need to change and a bigger vehicle is needed...
The good:
- Less than 1k miles on the following items:
-- KW Clubsport Suspension
-- Rear subframe bushings (solid)
-- Rear differential bushings (Hard poly bushings - these do have an
increase in NVH, so if you want to daily this, you may consider changing
back to stock)
-- Rear tires - Yokohama Advan V701 245/35/18
- Less than 5k miles on:
-- Brake Pads
-- Rotors
-- Front tires - Bridgestone Potenza S-04 225/40/18
- Berk technology Street Cat-back
- Major PIA items replaced under my ownership:
-- High pressure fuel pump
-- Oil filter housing gasket
-- Valve Cover Gasket
-- Oil pan gasket
-- Water Pump
Extras:
- Stock exhaust
- Spare set of front rotors
- Original lip spoiler
- Aftermarket trunk spoiler
The bad:
- The battery should probably be replaced soon. I don't drive the car much as its not my main driver, but every few weeks the trip/time/date will reset indicating a low charge. I throw the battery tender on it and it's good to go.
- There is a few inch crack in the paint, just below the driver rear window. It was like this from the time of purchase and it never bothered me enough to fix it. The car rarely sees bad weather, so I've just ignored it (See Picture).
- There are a few scuffs on the rear bumper, again prior to my ownership, it's not noticeable unless your looking for it (See Picture).
Pictures:
      10-09-2022, 08:19 PM   #2
Gustav_555
More pictures...
      08-10-2023, 03:40 PM   #3
Squib_
Drives: Infiniti G37S
Is this still for sale?
      09-11-2023, 07:13 AM   #4
Gustav_555
Yes, it's back up for sale.
135i, 6speed, m-sport
