      03-31-2008, 05:32 PM   #1
Adam@Riss Racing
Drives: 2006 Interlagos Blue BMW M5
**Riss Racing** Blowout Sale!!!
Good day everybody,
We are currently overstock and looking to get all our sets out this month! We should have another big batch early next month. There is no group buy, this is live on our site right now. These are the WORLDS MOST POWERFUL 135i/335i downpipes. Currently, Helix and Vishnu have made custom maps specifically from our Riss Racing Catless Downpipes. The map is specific with the flow from 3", tapering to 2.75" half way down the pipes, and tapering again to 2.5" to fit ANY stock or aftermarket catback system. These downpipes are 100% bolt on so no worry if your car is leased!
Power?
We made 27whp/49wtq on our prototype set which didn't flow this well. Tuned, VISHNU and HELIX have made 390+whp and 390wtq-410wtq.
Look?
We offer 2 finishes.
Stainless steel polished. Great look, also Bronzes after a few heat cycles which almost matches the stock exhaust completely!
Thermal/Ceramic Coated (Black). For a super stealthy look. Heat tested to 2200 degrees for 14 hours straight with no break down.
Sound?
Riss Racing Catless Downpipes w/ Stock exhaust
All other videos on our site.
Price?
$699polished/stainless steel finish
$799 real ceramic coated finish (baked on, not spray can thermal coating)
Please visit www.rissracing.com. Thank you!
      03-31-2008, 05:42 PM   #2
Riss Racing
Drives: E60 M5/E92 335/HUMMER H2
If you need detailed questions answered please PM me, and I will give you my personal cell number. Or you can call us on the shop line at 714-505-6873. Thanks!
      03-31-2008, 09:43 PM   #3
Helios
RFTs suck!
Helios's Avatar
Drives: F80 MW M3
i got blown away when i heard the sound clip!! i cant believe that just the DPs ..any sound clips coming from the 135i?
      03-31-2008, 09:44 PM   #4
E82tt6
E82tt6's Avatar
103
Drives: '08 Black Saphire Z4 MC
Woot! Good news! Ordering some coated pipes now.
I'll get the 1'er sounds a bit more aggressive, given how it sounds stock compared to the 3'er.
'08 Black Saphire/Black Z4 M Coupe
RIP Gretta: Blue Water/Lemon 135i. Died to save me.
-ChuckV
      03-31-2008, 09:49 PM   #5
135-CS
Drives: EVO8,EVO9,E90,E82
Would the cell ligth con out with this down pipes since are catless?
      03-31-2008, 11:08 PM   #6
Adam@Riss Racing
CEL can be fixed by an 02 simulator. We are in the works of making one now but you can always get Terrys 02 sims which will not trigger a CEL.
      03-31-2008, 11:40 PM   #7
Adam@Riss Racing
Thank you for your order. Will be sending it out asap. You're going with Helix on the tune/install? Just wondering!
      03-31-2008, 11:50 PM   #8
red_stapler
Drives: 2008 135i- Montego Blue/Lemon
Adam:
Will my car pass smog with these pipes?
Is it street legal if i do it?
Can i chip it with Dinan?
Will this viod an warrenty?
thanks
      04-01-2008, 02:19 AM   #9
Adam@Riss Racing
Originally Posted by red_stapler View Post
Adam:
thanks
Not sure about the smog. We haven't gotten it smogged but with stock 2ndary cats, there is a good chance.
This will work well with the Dinan tune. Just make sure you get 02 simulators so you don't have a check engine light. You shouldn't have any problem with warranty, but I would suggest taking the downpipes if you are taking the car to the dealer to service the engine.
Hope this helps.
      04-01-2008, 06:18 AM   #10
dim135
Drives: bmw 135
adam the mechanical fix will work on this car?
This mechanical O2 fix is basically a way to space out the O2 sensor so that it still reads SOME exhaust gasses but it removes the O2 sensor from the direct flow of the gasses as to make the ECU believe there is a restriction in the exhaust gasses such as by a Catalyst.
      04-01-2008, 09:07 AM   #11
Helios
RFTs suck!
Helios's Avatar
Drives: F80 MW M3
any benefits to the Thermal/Ceramic Coated DPs?
      04-01-2008, 10:10 AM   #12
Riss Racing
Benefits to Ceramic coating is keeping the heat in the pipe usually producing about 3 % power gain. Also lower eng temps, and DP protection. They are full 304 stainless steel so the protection isn't much of an add on. However it does have it's benefits.
      04-01-2008, 10:12 AM   #13
Riss Racing
There is only one person I know that does this. It is possible however there isn't much room. The O2 SIMs are used by pretty much everybody with catless and they work great! Thanks!
      04-01-2008, 12:23 PM   #14
E82tt6
E82tt6's Avatar
103
That's the plan! When the car gets back from Europe, I'll be picking up a piggyback/tune and IC from them. Maybe even a custom racegas map. :thumbup:
I'll do some before/after dynos for you when the car gets back. There's some speculation that the 135i exhaust might flow a bit better, given it's slightly louder.
-ChuckV
      04-01-2008, 01:33 PM   #15
Riss Racing
Looking forward too this!
      04-01-2008, 11:53 PM   #16
Riss Racing
I've had a few PMs in regards to this.....all DP are IN STOCK. You do not have to wait for the GB to end to get your DPs. Basically you are getting the best of both worlds. Group buy price with next day shipping. Most of you will have your DP before you have your car
      04-02-2008, 12:03 AM   #17
993 911
993 911's Avatar
47
Drives: Z3M, F31, G07
So if I order these and install them when my car comes, it will throw a CEL? Where do I purchase these 02 sims and how do they work?
      04-02-2008, 12:16 AM   #18
coco_m3
coco_m3's Avatar
Drives: Supercharged E90 M3
2008 BMW M3  [0.00]
2010 BMW E90 335i  [0.00]
BMS Makes one....
http://www.burgertuning.com/products.html
very bottom of the page...
      04-02-2008, 11:56 AM   #19
Riss Racing
Originally Posted by silverbullet135i View Post
BMS Makes one....
+1 you can ge them here if you need them right now....if not we are done making our and they have been tested we are just mass producing them now.
      04-02-2008, 12:26 PM   #20
Italteen3
Drives: 135i JB
My ship will be here by Friday!
Then its !
      04-02-2008, 12:42 PM   #21
coco_m3
coco_m3's Avatar
2008 BMW M3  [0.00]
if you get RissRacing Downpipes, just wait for them to start shipping their CEL fix...
thats what im gonna do...
Just my 2. cents.
      04-02-2008, 04:21 PM   #22
Adam@Riss Racing
Very shortly guys. We will have a discounted price on our 02 sims to go out to all the 1ers that purchase downpipes on the GB. Purchase now, and whoever is on the list will get the discounted price.
