08-20-2019, 02:33 PM | #1 |
672
Rep 1,778
Coilover preload for the track
So I have a new to me set of KW Clubsports(thx berns ). No helper springs. Swift linear springs. I have zero experience with coilovers so trying to learn.
With zero preload the ride height is still a bit more than I want in the front. Is it ok to have some negative preload as long as the spring lines up on the perches when I lower the car back down? I realize this does reduce bump travel for the shock. I read on a Miata forum that for racing, it is fine if the spring is loose when unloaded as the sway bar prevents the spring from becoming unseated when cornering, even if fully unloaded but I am not sure if that is correct. Request advice from the collective wisdom here...
Best,
Andy '12 E82-PS2,Stoptechs,Clubsports+M3 bits,Accusump,Wagner DP+EVO III FMIC,ERCP,BMS Intake,Mason Strut Bar,Wedge Tune |
08-20-2019, 03:05 PM | #2 |
Rep 777
If the spring can't miss the perch when you lower the car, then you are definitely ok (which is probably about -10 mm "preload"). More than that, you may still be ok, for the reason you state. If you need to go lower than that, I would proceed cautiously with lowering, and if you don't hear any nasty noises in transitions, carry on.
I also suggest confirming how much suspension travel you have from static to the bump stop contacting. Obviously if you lower too much you will be riding on your bump stops statically. If you have at least 15 mm static clearance to your bump stops, you are probably ok. |
AndyW672.00 |
08-20-2019, 08:36 PM | #3 | |
672
Rep 1,778
Best,
