      01-08-2021, 11:44 AM   #1
Dru128m
Drives: 08 128i E82 & 09 328i E93
2008 BMW 128I  [0.00]
2009 BMW 328I E93  [0.00]
The old cut up manifold into trumpets idea
So really I wanted to see this happen and nobody seems to have attempted it. So I guess I will. Made the manifold, PCV/CCV and evap valve to catch can, some catless headers, and a good tuner accepting the challenge. I'm out of reasons why it won't work, so here it goes. Wish me luck.
asbrr544.50
      01-08-2021, 04:32 PM   #2
desertman123
E82 Mudflap Ambassador
desertman123's Avatar
Drives: '08 128i
1992 Honda Beat  [9.50]
2008 BMW 128i  [10.00]
2014 BMW 528i  [10.00]
Do it, stock single stage manifolds are dumby cheap anyway
      01-09-2021, 02:24 AM   #3
jonwilli
Drives: E81 130i
I think Bob at StageFP ran the N52 without intake manifold when he worked at BPC and there was no issues. Maybe give him a call?
      01-10-2021, 02:06 PM   #4
JemBash
JemBash's Avatar
33
Drives: 2012 BMW 128i
Wat headers are you going to go with?
      01-10-2021, 02:46 PM   #5
Dru128m
Yeah, Bob is the man. He's the only tuner that was willing to touch it. Waiting on Bob's cable to arrive. Headers are cheapies from Mertop racing, but they look solid, welds appear decent, fitment will be known soon. If this actually works, I want to build a 6 into 1 header for it, dreaming. I'm really hoping for a kinda old school staccato sound.
      01-10-2021, 06:03 PM   #6
rjahl
rjahl's Avatar
996
Drives: Z4 35is
2012 Z4 35is  [0.00]
Just remember, without a throttle body you have no emergency throttle control in the advent of a failure with the valvetronic system
      01-11-2021, 01:35 PM   #7
Dru128m
Right, looking to set the fail condition to shut hopefully. If that's a no go for some reason at least it's a six speed and I can clutch in to kill the drive and then shutdown the motor. Sure, it's a tow home at that point but so are plenty of other things.
      01-13-2021, 08:13 PM   #8
Dru128m
Okay gentlemen (I use that term loosely) Bob has my DME files let's see what happens.
      01-15-2021, 02:45 AM   #9
oldman_stew
Drives: 2009 BMW 128i
Very interested in how this goes!
      01-15-2021, 10:22 AM   #10
spidertri
spidertri's Avatar
Drives: 11 128i 6MT Sport
2011 BMW 128i  [0.00]
Have any pictures of your intake trumpets? Did you make a plenum too?
It's a cool idea since we have valvetronic and you don't have to mess with ITBs along with the trumpet/plenum sizing.
11 128i slicktop
13 WK2
19 Alltrack S
      01-15-2021, 11:21 AM   #11
Dru128m
1st photo posted, not sure why but it really wants to be upside down. Nothing special for now just a stocker ran through the band saw. Once it works, we'll worry about good looks. Headers go on tonight, intake and flash Saturday morning.
spidertri397.50
SKI-R159.00
E92William1998.00
      01-16-2021, 11:28 AM   #12
E92William
Drives: 2008 E92 328xi
2008 BMW 328xi  [0.00]
That's super cool I wonder how it would drive. I had thought about doing that with a couple old single stage manifolds I have laying around, which seemingly when they were removed from the engine, their subsequent value was 0 lol. This seemed to perform better than the N54 manifold on the dyno runs they did at BPC.
It could use one of these piper cross filters that would fit all 6 runners like this:
      01-16-2021, 08:21 PM   #13
Dru128m
So the headers and manifold are installed. The ecu has the first flash on it. It runs and revs, sounds awesome, but I've yet to run it under load. All the codes that popped seemed sensible but I'm exercising caution till Bob has a look at the data. Once I get the thumbs up, I'll take it out and push it.
ornicar136.00
b1aze565.50
      01-17-2021, 01:32 PM   #14
Dru128m
Haven't heard back from Bob yet, but I thought a light test drive shouldn't destroy anything. Across town ran just fine, only used light throttle and stayed under 40mph. Idle is pretty steady and there's no stumble or hesitation as it loads up, feels pretty good. The sound of the intake is pretty sexy. The exhaust is pretty loud, but great growl, did I mention it's loud. We'll sort that out later. Anyway so far so good.
asbrr544.50
      01-17-2021, 01:41 PM   #15
Dru128m
Here's a look. Can somebody explain why my pictures regardless of orientation, post upside down. Tried rotating the originals to no avail. Maybe posting from PC instead of phone?
      01-17-2021, 02:47 PM   #16
SKI-R
Working towards usefulness
Drives: 128i, Tundra, B8S4
More interested in numbers than noise 😋, but I REALLY appreciate all of you who try new E82 things!
What’s the plenum plan, if any?
      01-17-2021, 04:04 PM   #17
rjahl
rjahl's Avatar
996
Drives: Z4 35is
2012 Z4 35is  [0.00]
How did you decide on the runner length?
      01-17-2021, 05:40 PM   #18
Dru128m
No plenum plan, all I really wanted was the noise. Once it's trimmed out and proven reliable I'll figure out a way to filter it. As far as runner lengths i figured with the low vacuum inside the manifold in stock trim that the runner length BMW came up with would at least work. I just cut the stock manifold along the stock plenum where the runners separated keeping as much flare as possible. Might do some dyno runs eventually.
      01-19-2021, 10:38 AM   #19
Dru128m
I can never think of everything. So, the intake air temp sensor is integrated into the MAF sensor. Would anybody happen to know the pinout from the MAF sensor, so I can hijack the correct wires and hook up a regular IAT sensor. Turner sells some kit to separate the IAT from the MAF, but I'm not scared to cut into the harness and run wires, I just can't find out which ones to grab.
      01-19-2021, 01:26 PM   #20
E92William
There is an oem IAT for N52s that plugs right in to the maf connector
asbrr544.50
      01-19-2021, 02:43 PM   #21
Dru128m
Could you find one of those for sale? New, used. I'd be happy with just the cable. The sensor is cheap.
      01-19-2021, 05:27 PM   #22
Dru128m
Thank you much good sir. I finally found a part number and have one on the way. Dumb oversight on my part, I didn't forget about IAT, just assumed since I didn't see it, it was up by the snorkel intake. That's why you don't assume things.
