      03-28-2016, 01:10 PM   #1
DSCPLN
BMW 1M
DSCPLN's Avatar
Drives: McLaren 600LT
"Check Engine" to "Turbos are Gone"
What a nightmare: After a recent spirited drive, the Check Engine light started coming on. Restarting the car would remove the fault momentarily, but it kept returning whenever I pushed the car. I had replaced a faulty fuel injector which was triggering a Check Engine light whenever I pushed the car a few weeks ago too.
So, I dropped the car off at the local BMW and they diagnosed it saying the turbos were done, as the wastegate will not open even by hand.
BMW told me that the "N54" may have the extended 8 year warranty on turbos, but not the "N54-T"
$7,326 USD parts & labor quote from BMW Dealer
$6,150 USD parts & labor quote from local shop for either BMW OEM Turbos or Dinan's N54 Turbo (4-6wk backorder)
I opted to Not extend the factory warranty. The car has about 30k miles on it.
Thoughts? Ideas?
      03-28-2016, 01:13 PM   #2
kikcaffine
Drives: 1m
Injectors were under warranty
      03-28-2016, 01:22 PM   #3
DSCPLN
BMW 1M
DSCPLN's Avatar
Yeah I just asked why they charged me on that one.
UPDATE: They're issuing me a refund on the charge. Thank you!
      03-28-2016, 01:23 PM   #4
kprocivic
kprocivic's Avatar
813
Drives: ecoboost s to the t
damn i thought all n54's were covered. i have the service bulletin for the wastegate warranty.
edit, after looking at the bulletin it did not include the 1m. thats bs.
2.0l ecosmackkaa
      03-28-2016, 01:38 PM   #5
kikcaffine
Drives: 1m
Yeah i was pretty pissed to learn that.
      03-28-2016, 01:44 PM   #6
css008
Drives: bmw 1m
That's a bit concerning as 30k over 5 yrs is not much mileage on the car. What type of bhp are you pushing? Did they give you a reason why the turbos went out?
      03-28-2016, 01:44 PM   #7
kprocivic
kprocivic's Avatar
813
Did they say why the n54t isn't covered by the extended warranty. I would keep climbing up the chain until someone says yes. 30k miles is low.
2.0l ecosmackkaa
      03-28-2016, 01:54 PM   #8
DSCPLN
BMW 1M
DSCPLN's Avatar
I don't have much performance-related mods on the car, mostly aesthetics: http://bit.ly/DSCPLN-1M
The dealer said they won't know for sure until they take it all apart.
      03-28-2016, 02:47 PM   #9
bdaddylo
bdaddylo's Avatar
Drives: 2017 F80 M3
I would go get a second opinion from an indy shop who's familiar with the N54. If you didn't abuse the turbos (i.e., tune with boost increased >16 psi) 30k miles is way too low for the turbos to die. Also, did they say both turbos are gone? IMO It would be highly unlikely for both to go at the same time. I personally would opt for aftermarket turbos like Pure instead of getting the OEMs again.
BTW - Nice mods!!!
_______________________
1991 E30 M3/Brilliantrot
2017 F80 M3/AW
      03-28-2016, 05:19 PM   #10
ayao
Thread killer
643
Drives: 1M
Ugh - very sorry to hear this. Keep us posted ...
      03-28-2016, 05:29 PM   #11
The Wind Breezes
Drives: 135i N55 DCT
New turbos are not a $6K-7K venture unless you are forced to have the car serviced at the dealer / don't know any better. Do it yourself / find a reasonable mechanic and it'll be a reasonable repair.
Also, if the turbos themselves are not blown and it's just your wastegate actuators, you know those can be replaced for RETARDEDLY cheap (if you do it yourself / have an inexpensive mechanic), almost all labor.
      03-28-2016, 05:34 PM   #12
DSCPLN
BMW 1M
DSCPLN's Avatar
Is the labor time for replacing the wastegate actuator, the same as replacing 2x turbos?
The cost of the turbos was $2k for both, $1k for just one. And I was recommended to replace both while they were in there, just-in-case.
The dealer matched the local shop at $6300, but won't budge on sanctioning the warranty as the "4 year" mark has exceeded.
Regret not extending the warranty on this car now.. but what were the odds?
      03-28-2016, 05:38 PM   #13
The Wind Breezes
Labor's probably the same, I can't imagine you could / would want to replace the actuators without pulling the turbos. It's not super hard to pull the turbos, I mean it's not like the motor has to come out or anything lol. I'm guessing from your replies though that you don't feel mechanically competent enough to attempt this yourself.
As for not extending the warranty, that's on you. Nobody in their right mind who's been around aging BMWs would opt out of any kind of warranty because ALL KINDS of expensive stuff can and will break.
      03-28-2016, 05:43 PM   #14
ayao
Thread killer
643
Drives: 1M
Turner has turbos for $720 a piece.
It seems really illogical that the turbo wastegate warranty doesn't apply to the N54T unless it's a different part number. Seems like there must be a way to escalate.
      03-28-2016, 05:49 PM   #15
The Wind Breezes
I just read up on this, apparently SOME of the turbos for the N54 are defective, hence the huge extended warranty.
If the N54T has the same turbos as the N54, which I can't imagine it doesn't, you may have a shot at talking your way into some coverage...it really depends on whether you can convince BMW to pay the dealer. The dealer will be happy to do any warranty work AS LONG AS BMW COVERS IT.
      03-28-2016, 06:30 PM   #16
DSCPLN
BMW 1M
DSCPLN's Avatar
BMW contacts anyone? Where's the 1M love?
      03-28-2016, 08:09 PM   #17
SpencerMH
SpencerMH's Avatar
Drives: 1M, M6 GC, 718GT4, F355GTS6
I had a similar experience, I have 67k miles and took my car in for rattling wastegates assuming it would be covered by the extended warranty like all other n54's but was informed the 1m doesn't appear on the list. This has to be a typo essentially, the bulk of n54s are 2010 model year and before so our 2011 n54's fall outside that list of cars that are covered but if someone goes the distance I can't imagine BMW won't cave as it's the same turbos with the same faulty design. We need an Atty owner to go the distance here on this issue!
And sorry to hear of your turbos, definitely bizarre they failed at that mileage and it's a prime example of why BMW was sued and then extended the warranty; you're looking at a multi thousand dollar repair because a $20 wastegate failed, a terrible design.
BSM 1M, MCS Coilovers, Pure Stg 2 Turbos, Walbro LPFP, JB4, BMS E85 Flash, ECS CF sealed intake, N54 Tuning DP's, Evolve Race Exhaust, Wagner FMIC, Stett CP w/ Tial BOV, ST BBK, Big Tires.
M6 6MT Gran Coupe w JB4, 718 GTS, Lotus Esprit V8TT, Duc 998SBayliss
      03-28-2016, 08:31 PM   #18
Ender_
Drives: BMW 1M VO, V60 Polestar '24
I wonder if it has anything to do with production date - one's closer to 2010 might not have the fix?
Just hoping because mine was a November production
As other have said I find it hard to believe it wouldn't be covered given the extended warranty if you make enough of a fuss.
      03-29-2016, 10:03 AM   #19
SpencerMH
SpencerMH's Avatar
No I don't think any 1m's or 335is's made the list as they were something of a afterthought when BMW switched to the n55 platform.
      03-29-2016, 10:11 AM   #20
DSCPLN
BMW 1M
DSCPLN's Avatar
they said the N54T turbos aren't the same as the N54
Final Quote for repair has been brought down to ~$5500. Thinking of just swallowing the cost
      03-29-2016, 10:24 AM   #21
MDORPHN
Drives: AW 1M
Turbos are identical. Only difference is the DME programming.
Neil
      03-29-2016, 11:22 AM   #22
DSCPLN
BMW 1M
DSCPLN's Avatar
accepted the repair cost. paying $5942 out of pocket >.<
expecting to get it back in 2 days
