      07-18-2011, 05:24 PM   #1
miula
Drives: a disturbed shark!!!
"Necessary" upgrades...
From reading through most of the posts here and some other resources I narrowed it down to the CDV modification or delete and the wheel locks being the essential upgrades that the car should have. However there are a few other mods I am debating with and just wanted to get an idea of what the gurus around here think about "necessary" upgrades for the 1M other than esthetics (LED angel eyes, kidney grills, etc). Keep in mind not all of us track our cars which would obviously entail a whole batch of mods...
Do we need:
1) Oil catch can (OCC) - if so, which one?
2) Blow off valve - if so, which one?
3) Cold air intake (CAI)?
I am sure I am missing most of the stuff, so pitch in...
Sorry if this has been asked before...
Miula
      07-18-2011, 08:51 PM   #2
richb811
richb811's Avatar
465
Drives: 2020 G20 330i M Sport
Tune. 340hp is nice. 400 is better
      07-18-2011, 08:57 PM   #3
1speedbike
1speedbike's Avatar
734
Drives: 2022 X4 M40i, 2008 135i
Assuming the N54 in the 1M is arranged pretty much the same as in previous applications and some of the same products work..
1) HPF OCC.
2) TIAL BOV
3) Stett CAI if it fits on a 1M. Not sure. If not, then AFE's stage 2 looks great, or just a drop-in filter works.
2022 X4 M40i - 2008 135i - 2015 F700GS
On Order - 2024 i4 M50
Scruffy's gonna die the way he lived... Mmhm.
      07-18-2011, 09:53 PM   #4
desertfox73
Drives: 2018 F83 / 2018 F85
I'm new to the world of mods, but am interested in learning (I'll be quick, I promise)...if folks post mods, do you mind writing out the full term? Otherwise, I have no idea what half of the acronyms mean.
Thanks, I hope it's not an inconvenience!
      07-18-2011, 09:58 PM   #5
UdubBadger
Drives: '04 330i ZHP
2004 BMW 330i ZHP  [9.50]
2011 135i  [7.46]
2008 328xi  [8.76]
I'll be honest, I would say at this point a cold air intake usually hurts these cars more than it helps them. UNLESS, you are driving around a track at the top end of the gears and can use the 3-5hp increase it gives out. If you're just an enthusiast/spirited driver on the highway or even worse, city... the intake usually snags away some low end torque to give way for the top end gain. To me, one of the more attractive parts of these cars is the mass amount of low end torque so i would hate to dip into that for a few top end ponies.
just something to consider.
plus if its not a true cold air (in the wheel well or front grilles) you have to deal with the mass amounts of heat soak.
      07-19-2011, 02:12 AM   #6
yemski
yemski's Avatar
Drives: 2011 1M
2011 1M Coupe  [0.00]
Originally Posted by miula View Post
From reading through most of the posts here and some other resources I narrowed it down to the CDV modification or delete and the wheel locks being the essential upgrades that the car should have...
Miula
wow I'm surprised that wheel locks aren't standard
      07-19-2011, 07:34 AM   #7
mrk
Drives: E60 M5, E82 1M
I've replaced the headlight switch with the EU unit, which provides the rear fog light button (no remapping needed). This keeps the Corolla and Camry drivers at a distance in bad weather.
I've also changed the rear view mirror for a HomeLink unit.
      07-19-2011, 07:44 AM   #8
clived
clived's Avatar
Drives: Evolved 1M
Do we need:
No! :-)
2019+ BSM M2C 2011-2012: VO 1M Coupe, many toys, Evolve Stage 3. 2008-2011: 135i M Sport Le Mans Blue / Lemon / HGSL. Evolve OBD remap - 390bhp. Also in the family: X3 M40d / Audi S4 (V8)
      07-19-2011, 07:48 AM   #9
Denso
Scotland
715
Drives: e46M3 Ruby, Porsche Cayman GT4
2015 BMW M4  [0.00]
Originally Posted by clived View Post
No! :-)
Agreed, seems a bit to suba-ishi or is it mitsi-baru. Blow off valves etc too rice racer for me sorry
      07-19-2011, 07:58 AM   #10
Drillslinger
Drives: BSM 1M / R53 / E91
I guess that depends... does BMW have any reliability issues with the N54 bypass valves? I owned an Audi 1.8T and it was notorious for killing the diaphram (sp?) on the std BPV so I finally bought a piston-BPV from Forge and it was rock solid.
Vorsprung durch Gas Geben!!
172 of 740
      07-19-2011, 08:08 AM   #11
kmpowell
kmpowell's Avatar
England
20
Drives: 1M
The VAG 1.8T uses a Diverter valve, not a Dump(Blow off) valve. Two very different things.
Blow off valves dump the air to the atmosphere (hence the whoosh noise), a diverter valve recirculates the air.
May '11 - Nov '11 - 1M Coupe. Gone but not forgotten.
Alpine White, Black Boston leather with Kyalami Orange stitching, Bluetooth, BMWP Kidney Grilles, BMWP Racing pedals
      07-19-2011, 08:10 AM   #12
1speedbike
1speedbike's Avatar
734
^^BOV isn't really necessary, but it's nice insurance to have one if anyone plans to tune their car and deal with higher boost levels. Something about the o-rings in the stock BOV isn't up to par IIRC. However I am running up to 13-14 psi at times with the stock BOV no problem.
Yeah the stett one is pretty much the only one that won't give you heat soat, which is why I mentioned it. Even the AFE dual cones I have make me lose a little bit of power down low, but I prefer the sound and the power increases a tiny bit when the boost gets very high, so it's a bit of a sacrifice.
Other mods to consider:
Short shift kit. Works wonders
Charge pipe (kinda goes with the BOV)
Clutch stop (if the clutch in the 1M is the same as in the 135i then you'll appreciate this)
Not required, but an FMIC will help lower intake air temperatures and will benefit on a track
that's about it.. the "importance" of everything else (chip/tune, suspension upgrades, etc) varies from person to person. I would stress that an oil catch can (OCC) is pretty important though. The HPF one is much better than the BSH one in my opinion, but some people run the BSH and like it. These engines get a butt-ton of carbon build up. You'll want to seafoam it once in a while.
      07-19-2011, 08:12 AM   #13
Drillslinger
Yeah sorry, it's been a while so I got my valve types mixed up but still, doesn't the N54 use the same type (ie DV)?
EDIT: Just saw 1speedbike's post. Makes sense, if you up the boost, look at upgrading the DV, otherwise... if the std one's aren't broken, don't fix'em
172 of 740
      07-19-2011, 09:15 AM   #14
Satalite
Satalite's Avatar
Drives: 128i
2009 128i  [10.00]
Tune will only get you 20-40HP max extra on top of stated 335HP. To go into 400's you would need intake/exhaust couple other mods.
      07-19-2011, 11:02 AM   #15
Dan Parker
Drives: 2012 Golf R
This might be considered off topic but the most necessary upgrade is...
seat time
Dan Parker
      07-19-2011, 11:06 AM   #16
rogbmw
Drives: Alpina B12 5.0
I agree with Dan (seat time), plus the three other things I am going to do is:
1. Replace the CDV (I just ordered one from Zeckhausen)
2. Headlight protection film (probably going to order the ones from Lamin-x)
3. Remove the Airbag warning labels from the sun visors.
      07-19-2011, 11:09 AM   #17
UdubBadger
2011 135i  [7.46]
2008 328xi  [8.76]
speaking of seats.... weight reduction = faster car without the addition of power so consider that too.
      07-19-2011, 09:43 PM   #18
miula
Thanx for all the input guys...
Seat time goes without a saying... However as soon as I get the car the first few things on my list are the CDV mod, black kidney grills and window tint.
By the way, anyone know a good place to do the CDV mod in Boston, MA or nearby. I don't have a pressure bleeder and I don't feel comfortable doing it by myself anyway. I did ask the dealer to do it on my 330xi and they refused (not standard BMW policy, blah, blah)
I am also considering an HPF catch can, V1 hardwire and lux angel eyes in the near future, since those are all DIY...
Although I read some mixed reviews on the catch can, so I am going to wait a bit for the dust to settle before deciding.
Maybe down the road I will have the performance seats (although I heard you can't have them coded in the US), exhaust system, cold air intake and some carbon fiber installed.
Thank you all for all the advice and great ideas,
Miula
      07-19-2011, 10:39 PM   #19
hollysmac
Drives: 2020 Bmw 228xi Gran Coupe
seat time
Correct. I always like to live with a car a while to see what I really need. I learned my lesson with my 1997 M3. I spent all this money; bumped my car into street prepared; went to Solo II divisionals and was the only car in my class not trailered there. I stilled had to drive the car every day unlike the folk who had dedicated cars never driven on the street. In addition all that money poured in that car did not make me a better driver.
      07-20-2011, 10:13 AM   #20
LuxAngelEyes
LuxAngelEyes's Avatar
Drives: BMW
When your ready for some LED angel eyes let me know. We offer the LUX H8 V3 angel eyes which will fit on your car.
      07-20-2011, 11:54 AM   #21
Redadair
Redadair's Avatar
Drives: 2011 1M #293 - 88 E30 M3
Necessary Upgrades? None!
You should be asking what people like to change on their cars? Because actually nothing NEEDS to be changed at all.
2011 1M, Valencia Orange, All options.
August 8th ED (#293 of 739 or 740)
88 E30 M3 100% OEM 73K Miles
02 E39 M5 Le Mans Blue 50K Miles
06 E46 M3 ZCP 58K Miles
      07-20-2011, 12:12 PM   #22
Red135
La Flama Blanca
Red135's Avatar
27
Drives: 1-series
Wow. Very well said.
