      03-07-2018, 05:38 PM   #1
JimVonBaden
BMW Cool Aide!
JimVonBaden's Avatar
Drives: 2011 128i Convertible
Raising the Armrest DIY
From the beginning the armrest height bothered me. It was too low to be comfortable and it blocked the use of the center console cup holder.
Saggy and not very functional.
I removed the armrest using instructions from here: http://www.1addicts.com/forums/showt...=234692&page=2
Once off, it took about 10 minutes to fix the issue.
Note that the armrest uses a block on the rest to hit on the mount block.
I drilled a 1/8" hole in the lug on both sides, but only through the contact side. I left the other to bottom the screw against since the plastic is soft and the threads would just strip out if you put much pressure on them. Use the length of the screw to set your height.
My first screws were screwed in to nearly flush, since I didn't know what I needed to get the height I wanted.
This raised it up about an inch, but not enough. I added longer screws, no photos, but they stuck out about 1/4" lug to screw top. This raised it up about 2.25", which was perfect form my arm rest, and allows the cup holder to hold a standard bottle of water or soda.
For some it may seem a bit goofy, but standing outside the car it looks fine, and is so much more functional.
Hope this helps someone who wants to do the same.
1and11858.00
ShocknAwe3232.50
Blu3RSX27.50
spidertri397.50
      03-07-2018, 07:37 PM   #2
1and1
Loves me some MHD!
1and1's Avatar
'09 135i  [10.00]
Nifty, may do this myself!
Amazing how it looks so obvious once you've seen it done, yet nobody else has done it yet... Good on ya man!
1and1
135i - E82.N54 2009 BSM - MHD / xHP / DCI, PR CP & 7.5" Race IC / N55 mid & Borla
      05-18-2018, 03:11 PM   #3
ShocknAwe
1Addict
ShocknAwe's Avatar
3233
Drives: E82 Mutt, M57 Truck
Perfect. I'll be looking into this tomorrow or there-abouts.
2010 135i 6MT Jet Black
      08-07-2019, 04:51 PM   #4
M_Riol
Drives: BMW 118d
Great job, dude!
I have exactly the same problem and I want to fix it ASAP!
@JimVonBaden do you remember the screw’s length which you used in the end? Maybe 12mm length? 20mm?
I want to use the same materials and measures you used, so that info would be very useful!
Thanks in advance and regards!
      08-07-2019, 06:10 PM   #5
dtla1
dtla1's Avatar
828
Drives: 2011 135i, Space Grey
Originally Posted by M_Riol View Post
Great job, dude!
It looks like your user tag didn't work for some reason, maybe because it's your first post. Hopefully mine gets JVB's attention: JimVonBaden
      08-07-2019, 09:53 PM   #6
JimVonBaden
BMW Cool Aide!
Sorry I missed the question. It was a 1/2" screw. I can recall what diameter.
Based on long term experience, when you figure out how high you want the screw, layer washers under it or it will push through over time.
dtla1827.50
