      04-11-2021, 10:27 AM   #1
machine4321
B14 Bilstein and preload
I’ve got 255/35-18 on my OE sport suspension with 18x8.5 et45 bmw 710s. I have no rubbing which is great but I was about to buy a b12 kit for strut clearance but noticed the b14 are cheaper right now and might as well have some adjustment. I know this will make me run spacers up front but I’m hoping I’ll be ok as my fenders are already rolled.
My question is this, I don’t want in much lower than stock, maybe 1/2 to 3/4” and definitely don’t want tuck. How much height can I get with the b14 before preload becomes an issues? A friend sent a pic of his and he’s running it low (maybe 1/4 of lower threads from the bottom. I would imagine I’ll be running near the top of the threads, A. To help with tire clearance and B. Cause I love suspension travel.
I’m wondering at what point does adding more height just compress the spring and add preload?
      04-15-2021, 09:35 PM   #2
sibanez
Drives: 17 Civic SI, 11 128i, 04 GX470
I believe the minimum with these is about 3/4 an inch of drop. You can crank them more, but the front struts don’t have a ton of travel. It’s been a while since I installed a set, but I do remember Bilstein having some min/Max recommendations.
      04-18-2021, 01:18 PM   #3
machine4321
That’s good news. Some of the pics I saw were very low in the front. I want to keep good travel. I was just worried but adding to much preload it would lose some compliance
      05-22-2021, 10:05 PM   #4
machine4321
Updating.
B14 are on and even with turner camber plates they are about 1/2” to low for me. Ive added as much height as I can but all its doing now is adding to much pre load And riding like pooh. The last 7-8mm of thread hasnt increased height at all so im guessing strut travel is topped out. The front tire is almost tucked but id like to have a good finger of height
So, how should I add. Easiest is washers in between Fixed camber Plates and strut towers But I fear putting to much stress in to that small of an area. Maybe have a flat plate same shape of camber plate made up?
Otherwise, spacer ring in between knuckle and the stop on the strut?
      11-04-2023, 12:27 PM   #5
Jback
Drives: 135i 09
Did you end up putting some type of washer underneath the strut in the same predicament?
