      01-02-2024, 09:10 AM   #1
HappyDuck
HappyDuck's Avatar
Drives: 2011 BMW 128i 6MT M-Sport
2011 BMW 128i  [0.00]
Which year 328i rear calipers for my 128i
I want to upgrade the rear brakes on my 128i (my fronts have already been changed to 135i calipers). I understand the calipers off a 328i are plug and play, but should I look for units from specific years?
Thanks
2011 128i M-Sport 6MT Coupe
Space Gray
Style 372 Wheels
Red Manual Sport Interior
      01-02-2024, 01:25 PM   #2
Suprgnat
Слава Украине!
Suprgnat's Avatar
Ukraine
2317
2013 128i  [9.58]
Thanks
34216768697 Left
34216768698 Right
From RealOEM:
Part 34216768697 was found on the following vehicles:
1' E81   (02/2006 — 12/2011)
1' E87   (02/2003 — 02/2007)
1' E87 LCI   (01/2006 — 06/2011)
1' E88   (11/2006 — 10/2013)
1' E82   (11/2006 — 10/2013)
3' E90   (02/2004 — 09/2008)
3' E90 LCI   (07/2007 — 02/2012)
3' E91   (02/2004 — 08/2008)
3' E91 LCI   (07/2007 — 05/2012)
3' E92   (05/2005 — 02/2010)
3' E92 LCI   (11/2008 — 06/2013)
3' E93   (09/2005 — 02/2010)
3' E93 LCI   (11/2008 — 10/2013)
3' F30   (02/2012 — 07/2015)
3' F30 LCI   (01/2015 — 03/2019)
3' F35   (06/2011 — 08/2015)
3' F35 LCI   (01/2015 — 03/2019)
X1 E84   (09/2008 — 12/2015)
Zinoro M12   (01/2013 — 07/2015)
Inertia is the enemy!
      01-17-2024, 10:10 AM   #3
HappyDuck
HappyDuck's Avatar
@Suprgnat Thanks!
Space Gray
Style 372 Wheels
      01-27-2024, 05:42 PM   #4
Geran
Drives: 2008 BMW 128i
How come the E90 328i brakes are an upgrade to the stock ones if they share the same part number?
      01-28-2024, 08:58 AM   #5
Suprgnat
Слава Украине!
Suprgnat's Avatar
Ukraine
2317
2013 128i  [9.58]
Stock 128i rear calipers are part numbers 34216768693/34216768694 and have 40mm pistons.
34216768697/34216768698 from the 328i are an ugrade to the 128i because they have 42mm pistons.
Geran4.50
      01-28-2024, 02:37 PM   #6
Geran
Stock 128i rear calipers are part numbers 34216768693/34216768694 and have 40 mm pistons.
Oh okay, in your post listing the 34216768697 showed it was part of the E82.
34216768697/34216768698 from the 328i are an upgrade to the 128i because they have 42 mm pistons.
Gotcha, that makes sense. Now to decide between this upgrade or upgrading to the 130i hubs and 135i rear brakes.
      01-28-2024, 11:26 PM   #7
SpeedyJay
Drives: BMW 128i, Mini CoopS
Is there a stamp on the 42mm calipers so we can be sure we are getting the right ones?
      01-29-2024, 01:15 PM   #8
Suprgnat
Слава Украине!
Suprgnat's Avatar
Ukraine
2317
2013 128i  [9.58]
128i
328i
Geran4.50
SKI-R159.00
Blau366.50
      01-30-2024, 01:46 AM   #9
MAMSport
MAMSport's Avatar
93
Drives: '13 128i M-Sport coupe
Worth noting here is that the rear rotors stay the same (i.e., E82 128i) even if using the E9x 3 series rear calipers. I believe (but am not sure) the caliper bracket stays the same as well. I forget whether the rear pads are different from the E82 128i and E9x 3 series, though.
E9x M3 front & rear suspension arms; BMW Performance brakes upgraded to drilled rotors in rear; BMW performance shifter; BMW Performance Exhaust; Wave Trac LSD with modified 'nannies'; BMW Euro Intake box; BMW Aluminum Strut Tower bar; ECS front and rear sway bars; 3 stage intake with BPC software; BMW style 78, 17 x 8" wheels with Bridgestone RE 980AS 225/45-17 tires; Koni Special Active struts/shocks, E9x M3 RTABs.
      02-19-2024, 12:53 PM   #10
carscatscoffee15
carscatscoffee15's Avatar
Drives: BMW 128i ZED Package
Why not F30 rotors/brakes? Just out of curiosity
I'm trying to decide which route to take in my brake upgrade.
Mods Done: AA Exhaust/Headers | 3SIM | MILVs | StageFP Dyno Tuned | Euro Box Intake Swap | LCI Blackline Tailights | OEM Euro Bi-Xenon Swap from Halogen | Rear Bumper M-Sport Swap | Rear PDC Retrofit | BMW OEM CF Diffuser/Spoiler | BMW Front Aero Kit | Supersprint Sec 1 Cat Delete Straight Pipes
To Do: Ohlins R n T Suspension | Front/Rear Sway Bars | M3 Front Control Arms/Bushings
Eventually: AT -> MT Swap (!?)
      02-21-2024, 08:49 PM   #11
Geran
F30 brakes on the front work great. To put them on the rear is a little harder unless you use the SLG brackets, but that forces you to use 18in wheel.
      02-21-2024, 11:50 PM   #12
carscatscoffee15
The SLG bracket is only needed if you go M3/M4 BBK 380/370 front/rear, if im not mistaken. There's a thread on here that covers that (and I'm not interested in that specific setup)
You don't need a bracket if you're going 370/345 S2NHA M Sport/ZTR option or M Performance BBK (these two are the same, the former are the blue calipers with 370s/345 out of the assembly line or the red/orange/yellow retrofit kit)
      02-22-2024, 10:50 AM   #13
Geran
Interesting, thanks for that information. I didn't know that.
