      08-09-2011, 07:31 PM   #1
997Houston
Drives: 2011 VO 1M
Transmission Oil Change
I took the 1M in for 1200 mile service. Oil changed and tranny and diff oil backordered. Now the service advisor says they have the oil for the diff change and BMW says the tranny oil is lifetime and never needs changing. Anyone else getting this story?
      08-09-2011, 07:42 PM   #2
Franklin Joseph
Drives: BMW
read this thread...it'll cover everything on the first service.
http://www.1addicts.com/forums/showthread.php?t=541737
i assume you took it to Adv Midtown? My SA is Al Lloyd and he's familiar with the tranny fluid. They screwed up on mine and had to special order the tranny fluid. Based on the thread above, transmission fluid flush is not a requirement.
As for the diff fluid, same happen to me, but its actually the modifier that they dont stock. The diff fluid itself they have it (in a drum). They got the modifier from Momentum.
      08-10-2011, 09:08 AM   #3
997Houston
Drives: 2011 VO 1M
Franklin,
Thanks for the update. How's the lowered suspension on coil overs on Houston streets?
Thanks,
Bill
      08-10-2011, 09:21 AM   #4
Franklin Joseph
Drives: BMW
very comfortable on highways/smooth pavement...gets abit bumpy in downtown...overall a happy camper.
      08-10-2011, 10:20 AM   #5
Red135
La Flama Blanca
Red135's Avatar
27
Drives: 1-series
Read the Service booklet that is included with the owners manual. The trans fluid in the 1M doesn't get changed.
AMS, Berk Technology, aFe, ER
      08-10-2011, 03:51 PM   #6
JimD
JimD's Avatar
368
Drives: 128i convertible
I changed my 128i to MTL (Red Line) at about 1800 miles. I was a little late. I did it based upon the old school maintenance guidance from the guy who writes the repair column for the Roundel (Mike Miller I think his name is). I also changed the differential to Red Line synthetic lube at that time. This expert uses their engine oil too as well as their transmission and differential lubes. The cost is quite reasonable, I order from JEGS.
Jim
