      10-20-2011, 10:35 AM   #1
Alekshop
Alekshop's Avatar
Drives: E30 M3 l E46 M3 l GT4 l 991 RS
✪ Alekshop | 1M Adjustable Camber Plates
Adjust it how you like it !
Now you can adjust Camber and Caster while keeping the stock suspension setup.
Ground Control has developed a very high quality product that allows you to set your car for the track in just a few minutes.
BMW 1M Camber / Caster plates feature over 26mm of total camber adjustment with the ability to make corrective caster changes to equalize side-to-side caster in the stock position.
Unlike the other camber plates on the market, Ground Control develoved a street version that offers replaceable waterproof German axial load bearings, more durable urethane bushings, less deflection, and a smooth silent ride on stock or stock sized aftermarket springs.
Ground Control camber plates are also engraved with the markings which can be used to locate the plate in the stock position for easy, repeatable, adjustment from street to track and back. All components are anodized or zinc plated for corrosion resistance.
It will be a great addition to KW V3 kit if you didn't get a ClubSport version.
You can place your order on our website here - 1M Ground Control Camber Plates
If you have any questions please feel free to contact me directly.
Aleks
✆ 925.609.4559
info@alekshop.com
@ www.alekshop.com
