      08-22-2020, 10:56 AM   #1
Iwantbjz
Drives: BMW 135i
Real Minimal Effort Alternative To Walnut Blasting
Hey guys we all know what a PITA it is to clean the intake valves on these direct injection engines and to be honest I don't have the money to be walnut blasting the car as often as I like or really trust anyone doing it. I tried the CRC method but it took for ever. I decided to try a couple of alternatives and found something pretty amazing. For around $25 you can use the CRC mixed and the result are insane so i thought This would help A LOT of people on here that don't have the time or money to buy all the equipment and do the plasting themselves or drop the car off at a shop and wait a day or two. I KNOW this will helps some of you.
There is a comparison of just using CRC and adding the Secret sauce:
c0bra185.00
      09-06-2020, 11:26 AM   #2
AForceNinja
2011 BMW 135i  [7.00]
2016 BMW M3  [0.00]
Dude wear some gloves
2011 135 w/ DCT + Some Things
      09-09-2020, 12:45 PM   #3
Iwantbjz
Drives: BMW 135i
HAHAHA Yea you are absolutely correct.
      09-11-2020, 10:58 PM   #4
///Makis
///Makis's Avatar
Drives: BMW 128i
Isn't brake cleaner a bit harsh on those Metal components?
Also I'd recommend a turkey baster or syringe with aquarium airline tubing, it might save a couple rolls of shop cloths.
In my opinion a safer alternative to this would be alcohol and naphtha or kerosene. I think the alcohol being moderately polar would work well in dissolving the crud and kerosene is also a very good solvent, so it could thin and dissolve the carbon build up.
But just my two cents.
Have you tried that seafoam Intake cleaner that you spray in after the MAF while the car is running?
I heard some people say it works and others actually use a borescope after and saw it made very little difference.
      09-13-2020, 09:44 PM   #5
Iwantbjz
Drives: BMW 135i
Brake Cleaner will not hurt the aluminum, steel, or bronze components in the head. To be extra sure the brake cleaner formula chosen is non-chlorinated so it is even easier on the metal.
The turkey baster is a really good idea actually but i used exactly 1 roll of towels so it was not that bad but i will save you from having to get that on your hands.
I have not tried the seafoam but will definitely give it a shot in the future. Thanks for the advice.
