06-07-2011, 05:46 PM | #1 |
Rep 391
Run in service
When you guys start to take your cars in for the 1200 mile service be sure you ask your service advisor if they have the right transmission fluid. Apparently it is not the same as the M3. It is a new formula and not kept in stock unless the dealer actually knows about it and has some on hand.
My car is sitting on the rack at the dealer now and it will sit there until they can get the correct fluid from Germany. |
06-07-2011, 06:54 PM | #3 |
Rep 22,992
Is it MTF-LT4 ?
That is what I used in my 135i 6MT tranny. http://www.1addicts.com/forums/showthread.php?t=409293 The rear diff fluid should be the same as the M3's = Castrol SAF-XJ I used the SAF-XJ bc it is backwards compatible in non LSD trans too. Dackel |
06-07-2011, 07:17 PM | #4 |
Rep 72
I thought i read in the supplemental maintenance manual that the transmission fluid is not suppossed to be changed as part of the run-in service. My dealer changed mine as part of the run-in service and since i did not find out until after the fact, i just let it go. Now after reading your post i think i will check back with them to make sure the they used the right transmission fluid. Thanks for the heads-up!!
06-07-2011, 08:08 PM | #5 |
Rep 391
i'll post more when they get back with me on what exactly was needed. they just said it was new and wasnt the same as that in other M's and was no where to be found in the US from what they could tell. They were working with BMW NA to get more info too.
06-07-2011, 08:36 PM | #6 |
Rep 22,992
FYI... the 1M has the SAME trans as the 2011 & '12, N55 135i has. It shouldn't be that hard to get the proper fluid.
06-07-2011, 08:53 PM | #7 |
Rep 391
06-08-2011, 01:36 AM | #8 |
Rep 22,992
According to RealOEM... the 1M's trans part number is: 23007599342 http://www.realoem.com/bmw/showparts...21&hg=23&fg=05 And... that trans is used in these following cars... Part Cross-reference RealOEM.com Home E82: Details on E82 E82 135i Coupe E82 M Coupé Coupe E88: Details on E88 E88 135i Convertible E90N: Details on E90N E90N 335i Sedan E92N: Details on E92N E92N 335i Coupe E93N: Details on E93N E93N 335i Convertible F10: Details on F10 F10 535i Sedan Dackel |
06-08-2011, 04:37 AM | #10 | |
Rep 697
Drives: M3 F80 silverstone
but maybe the transmission being exclusive was just another marketing saying like valencia organge would be exclusive
if you're cast on thin ice, you may as well dance
enjoy your cars |
06-08-2011, 04:53 AM | #11 | |
Rep 31
Maybe a quick email from a few members to germany might get a response on this matter. |
06-08-2011, 06:35 AM | #12 |
Rep 812
Can you point me at official BMW publication where they said VO would be exclusive only to the M1 - interesting.
2019+ BSM M2C 2011-2012: VO 1M Coupe, many toys, Evolve Stage 3. 2008-2011: 135i M Sport Le Mans Blue / Lemon / HGSL. Evolve OBD remap - 390bhp. Also in the family: X3 M40d / Audi S4 (V8)
06-08-2011, 09:50 AM | #14 |
Rep 1,417
+1 this is what BMW has said about the Trans in the 1M, Dry sump different synchros to reduce friction.
2011 1M, Valencia Orange, All options.
August 8th ED (#293 of 739 or 740) 88 E30 M3 100% OEM 73K Miles 02 E39 M5 Le Mans Blue 50K Miles 06 E46 M3 ZCP 58K Miles |
06-08-2011, 09:53 AM | #15 | |
Rep 697
ah, now i understand, of course they did not say exclusive to the 1m only - thats exactly the option marketing guys left open - they were careful choosing the words what a naive guy i must be - i am glad you opened my eyes however, i did not mean to spread any hate - no hard feelings
enjoy your cars Last edited by evolution80; 06-08-2011 at 10:02 AM.. |
06-08-2011, 09:55 AM | #16 |
Rep 1,998
Data I have for the Gear box:
Manual�gearbox (Code�letter�and�additional �info) GS6-45BZ (K�uncooled) As�always�for�M�models,�a�running-in�check�is�required�at�2,000�km/1,200�miles. The�running-in�check�includes�engine�oil�change,�manual�gearbo x�and�rear�differential. The�BMW�E82�M�Coupe�uses�the�GS6-45BZ�manual�gearbox�referred�to�for�short�as�the�K �gearbox. High-precision�shifting�achieved�by: • The�use�of�a�newly�developed�carbon�friction�linin g�on�the�synchromesh�units • A�newly�developed�and�very�low-friction�shift�mechanism • The�low�drag�losses�of�the�gear�train • Limiting�excessive�shift�travel The�gearbox�has�been�tested�and�approved�for�a�max imum�torque�of�500�Nm�for�the�E82.�Testing�was based�on�the�permissible�gross�weight�and�the�maxi mum�possible�forward�thrust. To�keep�the�drag�losses�low,�dry-sump�lubrication�is�used.�Compared�with�convention al�immersion�lubrication, �this�prevents�the�swash�losses�from�the�movement� of�the�gear�train�in�the�sump�oil.�Further reduction�of�losses�is�achieved�by�the�friction-optimized�radial�shaft�seals. Gearbox�technical�data K�manual�gearbox GS6-45BZ Present�engine�applications�on�1�Series N55B30M0/N54B30T0 Maximum�drive�torque [Nm] 470 (500�approved�for�E82) Weight�inc.�oil [kg] 43.3 Gearbox�length [mm] 646 Transmission�ratio�1st�gear 4.110 Transmission�ratio�2nd�gear 2.315 Transmission�ratio�3rd�gear 1.542 Transmission�ratio�4th�gear 1.179 Transmission�ratio�5th�gear 1.000 Transmission�ratio�6th�gear 0.846 Transmission�ratio�reverse�gear 3.727
06-08-2011, 10:02 AM | #17 | |
Rep 812
06-08-2011, 10:05 AM | #18 |
Rep 697
yes right, now i recall my salesperson saying: ...and it is the only car with this exclusive orange-color - adding:at least at the moment
enjoy your cars |
06-08-2011, 10:20 AM | #19 |
Rep 3,939
Transmission was revised for 2011. The 1M has the same tranny as the one on 2011 models. This is also confirmed by part numbers.
06-08-2011, 12:09 PM | #20 |
Rep 3,094
06-08-2011, 03:16 PM | #21 | |
Rep 22,992
Actually, BMW never said the 1M trans would be exclusive either! Just like the paint, you read into it what you wanted to believe. The 1M trans does have low friction syncros and has been reworked. But it is also shared with the "normal" 135i as well. Dry sump... I dunno... ? I believe all N55's has this new improved trans. I thought that is also why the Perf SSK doesn't work on a N55 or a 1M - bc of this new trans and its new shift linkage.. Dackel |
06-08-2011, 05:50 PM | #22 |
Rep 1,421
My dealer just called to tell me to bring the car in and they would store it for 2-3 weeks while they wait for the correct fluid. They did the 1200 mile service almost 3 weeks ago and I've put about 1K miles on it as well as 1 track day. Awesome! They will be covering my transmission for an extended period if I have anything to do with it.
Here's the memo: To: BMW Service Managers, Shop Foremen, and Technicians Subject: 1 Series M Coupe 1200 Mile Service – Manual Transmission MTF LT5 Fluid Not Available The 1 Series M Coupe requires a manual transmission fluid change. Due to a shortage of the new MTF LT5 manual transmission fluid, this specific service should not be performed until further notice. The other procedures for the 1200 mile service can be performed. Do not substitute MTF LT5 fluid with any other fluid. No premature wear will occur to the manual transmission if the fluid is not changed at the 1200 miles service. We apologize for this inconvenience, and will provide additional information shortly.
Dan Parker
